Hi
I've be carrying out a full service on the weekend and im just wondering where under the car do i drain the oil? |
If it is, make sure you park in a place you don't mind an oil spill or cover the ground with a large absorbent material. I'll get a picture up here in a minute to help you. Here you go... your interested in #4 and #5 of the top picture. The oil pan nut is 13mm. Changing oil and filter takes 5 quarts. Put a thin film of oil on the rubber gasket of the new oil filter before screwing it on. Turn the filter by hand till it stops turning then use a filter wrench and tighten it 1/4 turn more. NO more than that.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 20 Aug 2009 at 06:09 pm. |
I know what your saying and you and I know that but telling someone to just hand tighten it, they might get the idea to just stop turning as soon as it stops turning and I don't think that's enough. Under pressure you'll have oil pushing out and it might even turn itself out with vibration. That's why I suggest 1/4 turn past hand tight.
...and my story. FREE oil change with purchase of tires. This was on my Vette where the oil filter is screwed into an oil cooler. Next time I went to change the filter, like you, it wouldn't budge, AT ALL. When it did start to move with a lot of pressure, the oil cooler started to turn and that was put on with an impact wrench with more pressure than you can imagine. I had to unscrew the water lines that went to the cooler so the filter and cooler could turn and the whole thing could come off so I could work on getting the filter free from the cooler while it was on the work bench. That's the last time (20 years ago) that anyone ever changed the oil but me.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 20 Aug 2009 at 07:20 pm. |
I have NEVER used a filter wrench to tighten the filter, once you put a thin film of oil on the "O" ring and tighten it as tight as you can by hand that is more than enough.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
That's tighter than anything I've ever had to deal. If I remember correctly, I've only ever had someone else change my oil once. I didn't have a heated garage and the temperatures were ridiculously low that winter. Luckily they didn't mess it up. Anyway, good luck to the original poster. Since it doesn't sound like you've changed oil before, get yourself a drain pan. Don't try to improvise with anything. This is recommended: ![]() If you can't find one or only plan on changing your oil once for some reason, one of these is cheaper and will work:
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
I used to work at a shop doing oil changes and tires. One car came in with a rounded off drain plug. I have a pair of Channellock "Nutbusters" that will remove just about anything but that drain plug was in tight enough that I couldn't budge it. I sent them back to the idiot dealership that did the oil change last.
At work (air-cooled aircraft engines), we coat the rubber oil filter gasket with Dow Corning DC4 compound...it is a silicone dielectric grease good to 400F. Never had a problem removing a filter when this grease was used. As for how tight...follow the filter manufacturer instructions (usually printed right on the can).
| coolant leak from the radiator drain | geronimo | Tech & Performance Forum | 1 | 19 Jul 2009 02:55 pm |
| Help! How to drain and refill automatic transmission? | crooner44 | Tech & Performance Forum | 7 | 11 Jun 2009 01:42 pm |
| Oil drain plug | AlmondTurbo | General PT Cruiser Discussions | 2 | 07 Feb 2007 04:54 pm |
| Check & drain you water heaters, A/C , &.... | Espresso | Non-PT Discussions | 17 | 12 Jul 2005 11:47 am |
| Drain plug | DREAM2 | General Turbo Discussions | 11 | 06 Jul 2004 10:14 am |
