Recently bought a 03 limited with almost 93k miles on it and its got some bad gas mileage. Last time i was mostly highway and only got 162 miles between fill up. any ideas on what it could be?
added info: recently changed the spark plugs for some bosch +2... the ones that have two metal thingys at the end except 1... lol dont know about mechanical terms. |
A few things you can do to improve gas mileage is
1. Fixing a serious maintenance problem, such as a faulty oxygen sensor, can improve your mileage by as much as 40 percent. 2. You can improve your gas mileage by around 3.3 percent by keeping your tires inflated to the proper pressure. Under- inflated tires can lower gas mileage by 0.3 percent for every 1 psi drop in pressure of all four tires. Properly inflated tires are safer and last longer. 3.Use the Recommended Grade of Motor Oil You can improve your gas mileage by 1-2 percent by using the manufacturer's recommended grade of motor oil. For example, using 10W-30 motor oil in an engine designed to use 5W-30 can lower your gas mileage by 1-2 percent. Using 5W-30 in an engine designed for 5W-20 can lower your gas mileage by 1-1.5 percent. Also, look for motor oil that says "Energy Conserving" on the API performance symbol to be sure it contains friction-reducing additives.4. I have always been told also that a clogged air filter causes bad gas mileage, howevr, I found this NEW INFORMATION: Replacing a Clogged Air Filter on Modern Cars Improves Performance but Not MPG A new study shows that replacing a clogged air filter on cars with fuel-injected, computer-controlled gasoline engines does not improve fuel economy but it can improve acceleration time by around 6 to 11 percent. This kind of engine is prevalent on most gasoline cars manufactured from the early 1980s onward. Tests suggest that replacing a clogged air filter on an older car with a carbureted engine may improve fuel economy 2 to 6 percent under normal replacement conditions or up to 14 percent if the filter is so clogged that it significantly affects drivability. That's a few things you can check, also driving at a lower speed, such as 55-60 helps gas mileage performance by like 4%. spark plugs was an excellent thing to do, I would check tire pressure next and be sure I have fresh oil of the proper type reccomended and go from there. O2 sensors ( for my 2001 limited) was about $70, but worth it. I recently done some research on this subject, and that's the information I kept seeing time after time. Hope it helps.
Other than that, what you've stated is a good starting point for figuring out the problem.Is there a check engine light on? It's in the lower left gauge. It's orange and is roughly the shape of an engine. Also, have you had your timing belt changed yet? It's due if you haven't.
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
There is a "sticky" at the performance section that tells you the specs and correct way to change the spark plugs, including the materials to use when doing it.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
These are all great posts with some good advice. Another quick test to perform is to listen for any hissing or suction sounds coming from your engine at idle. If it sounds like there's air being pushed out or sucked in you may have a vacuum leak, which is a big mpg killer. Some places to check: 1) all Vacuum hoses 2) Throttle body gasket 3) TB shaft warpage 4) Intake Manifold Gaskets 5) Check intake manifold for warpage 6) EGR Valve (not sure if the 03 limited has one) 7) Valve cover Gasket Hope this helps, good luck.
2003 Touring Edition. 65k
Here's to a long life and a happy one. A quick death and an easy one. A pretty girl and an honest one. A cold beer and another one! ![]() |
I was just pointing out that AFTER he gets his problem resolved to not expect more than 20-24 mpg because you aren't going to get it city driving a PT.
2006 Limited, Auto, 90k miles |
This Black Thing Keeps Chasing Me ![]() YES ! That is a Ron Paul for President Sticker.. ![]() Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood ![]() Ed Sidders , Lake-O The-Pines , Northeast Texas Last edited by edsidders; 25 Aug 2009 at 12:02 pm. |
| Gas Mileage | PCC | Tech & Performance Forum | 64 | 31 Mar 2010 08:48 pm |
| Mileage Report | dcathy | PT Cruiser Convertible Forum | 10 | 28 Dec 2008 06:11 pm |
| 2006 PT Limited Ed Mileage is terrible. | vetteloverpa | General PT Cruiser Discussions | 45 | 11 Mar 2008 12:09 am |
| Horrible gas mileage | maxxheadroom | Tech & Performance Forum | 3 | 21 May 2007 08:51 am |
| Gas Mileage for you NA PT Cruiser | matt87951 | Tech & Performance Forum | 7 | 16 Mar 2004 01:17 pm |
