P0441? umm... what?
Old 03 Sep 2009, 03:10 pm
Default P0441? umm... what?
P0441 Evaporative Emission Control System Incorrect Purge Flow
whats this mean... got check engine light come on while driving and thats the code i got
2003 PT Cruiser Limited
92k Miles
Happy as a clam with it
Old 03 Sep 2009, 03:30 pm
Default Re: P0441? umm... what?
Loose gas cap, did it happen after a recent fill up??
Old 03 Sep 2009, 03:39 pm
not really... I filled up a couple of days ago. driven about 120 miles then it turned on
92k Miles
Old 03 Sep 2009, 04:20 pm
A couple of things can cause that error code but 99% is what Hooligan has suggested. Go out to the PT, take the gas cap off, put it back on and make sure it clicks at least 3 times when turning it closed. It can take a day or so for the fault light to go out. The computer will test it several times and if it was the cap will turn off the light.
Old 03 Sep 2009, 08:22 pm
You will need to replace the Natural Vacuum Leak Detection pump. It's on the right side of the gas tank, on the side. There is a sensor inside that checks the evaporative emission system. That sensor has a bad habit of going bad. It could be the supply hose from the solenoid to the tank but most likely it's the NVLD. Not that hard to do if you have a lift, otherwise dang near impossible. You have to drop the gas tank about 6- 8 inches. The part is not that expensive. If you have it done at a shop I would estimate around 2 - 3 hundred at the most.
Old 03 Sep 2009, 08:59 pm
will do
92k Miles
Error P0441 topgunffx General PT Cruiser Discussions 8 12 Mar 2011 11:04 am
P0441 - not the gas cap bobdole369 Tech & Performance Forum 1 16 Jun 2009 11:53 am
Code P0441 AkiraCruiser General PT Cruiser Discussions 4 09 Apr 2009 07:02 am
P0441 error code apollobey Tech & Performance Forum 2 07 Oct 2005 09:38 am
