Stuck oil drain plug
  #11 (permalink)
Old 05 Sep 2009, 06:22 am
Default Re: Stuck oil drain plug
Check the salvage yards.
  #12 (permalink)
Old 09 Sep 2009, 09:23 am
Wink Re: Stuck oil drain plug
I just had a striped out drain plug when changing oil and found that Napa has a oversize,self tapping plug that worked great for under $4.after the first run in I pulled the new plug and ran a qt of oil thru to wash out any chips,this really worked good. hope this helps, 01 PT/5spd.
  #13 (permalink)
Old 09 Sep 2009, 10:29 am
Originally Posted by jdmickies View Post
I've got a stuck oil drain plug. The last time the dealer had to heat up the pan to remove the bolt, now it's stuck again. Will I be able to drain most of the oil from removing the filter? I can't afford to replace the oil pan right now and I'm desperate to change the oil.
Thanks.
Aftermarket transmission pan with a drain bolt would sell like crazy.
For your engine - get the Fumoto valve already dude....... Part # F-106
FUMOTO ENGINEERING
  #14 (permalink)
Old 09 Sep 2009, 02:15 pm
When you say the plug is stuck I assume you mean just over tightened.
You should be able to get it loosened somehow.
First try to remove it with a six sided socket not a twelve sided one if the bolt head is not yet stripped out. This and a long socket wrench or breaker bar is what I'd try. The same socket on the end of an impact would If the head is really stripped you may have to go the pipe wrench or vise grip route.
Then get a new plug.
  #15 (permalink)
Old 09 Sep 2009, 02:18 pm
No, then get a Fumoto valve.
  #16 (permalink)
Old 02 Nov 2009, 06:20 pm
I have to go the impact wrench direction. It's way too damn tight. The plug was replaced at the dealership a while back and they had to heat up the pan to get it out. I've seen the rethread kits at pepboys, but none that fit M14x1.50 (current plug). Could I just retap the thing and flush it with oil?
Owner of Bessy, '02 Limited Steel Blue & Gidget, '02 Limited Blue Woody
Radiator drain plug Mapper Tech & Performance Forum 16 15 Jul 2009 08:06 pm
Oil drain plug AlmondTurbo General PT Cruiser Discussions 2 07 Feb 2007 04:54 pm
eBay Fraud for Drain Plug CREWZIN Non-PT Discussions 6 28 Feb 2005 06:35 pm
Oil drain plug valves gonzomania General PT Cruiser Discussions 6 28 Jul 2004 01:35 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
