Stuck oil drain plug
Old 04 Sep 2009, 01:48 pm
Exclamation Stuck oil drain plug
I've got a stuck oil drain plug. The last time the dealer had to heat up the pan to remove the bolt, now it's stuck again. Will I be able to drain most of the oil from removing the filter? I can't afford to replace the oil pan right now and I'm desperate to change the oil.
Thanks.
Old 04 Sep 2009, 02:01 pm
Default Re: Stuck oil drain plug
it's an '02 with 99K miles
Owner of Bessy, '02 Limited Steel Blue & Gidget, '02 Limited Blue Woody
Old 04 Sep 2009, 02:55 pm
Sorry No. Taking the filter off will only give you a little over what the filter holds. You can drain the pan by buying a suction pump and a length of tubing. They have hand pumps or electric.
Old 04 Sep 2009, 03:01 pm
that's what I was afraid of, even though the filter is right on the pan. Think an imact wrench would get it off? Hopefully, without stripping the bolt.
Old 04 Sep 2009, 03:16 pm
fastdel's Avatar
Send a message via MSN to fastdel
we had a post like this not long ago lol
ALSO KNOWN AS JCCC
Old 04 Sep 2009, 03:49 pm
what sort of pump will I need to look for? I've got a siphon hose pump. I'm sure i'll need to create a seal around the hole for the filter. Will that work or cause any oil pump issues? I can't afford the $300 to replace the oil pan.
Old 04 Sep 2009, 05:02 pm
chrysler oil pan with bolt::
Ebay
Chrysler 2.4L Oil Pan 2.4 PT Crusier
0 Bids $10.00
$50.00
+$15.00 for shipping
Old 04 Sep 2009, 05:49 pm
how tough to replace?
Old 04 Sep 2009, 06:05 pm
pull up on some ramps Un bolt the pan be careful as it is full of Oil
lean the pan away from you so it can pour in a bucket
scrape the old gasket off the block reinstall gasket and pan
should it be the hard at all:::
Old 04 Sep 2009, 09:29 pm
anyplace sell new/used oil pans? I can't seem to find any other place online, other than the one ebay post, that sells them.
Radiator drain plug Mapper Tech & Performance Forum 16 15 Jul 2009 08:06 pm
Oil drain plug AlmondTurbo General PT Cruiser Discussions 2 07 Feb 2007 04:54 pm
eBay Fraud for Drain Plug CREWZIN Non-PT Discussions 6 28 Feb 2005 06:35 pm
Oil drain plug valves gonzomania General PT Cruiser Discussions 6 28 Jul 2004 01:35 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
