2 error codes
Old 05 Sep 2009, 07:00 am
Default 2 error codes
hi ive done the key trick and came up with these to errors
1130
0243
need help on there meanings and how to fix the problems many thanks
Old 05 Sep 2009, 07:11 am
Default Re: 2 error codes
granty,
Welcome to the PT Cruiser Links forum.
Please introduce yourself with the basic information about your PT like the year, mileage and previous maintenance that was performed. Also tell us if your still under any kind of warranty. That will help us give you some advice to fix your current problem.
Things change throughout the years of the PT so telling us what year you have narrows down the problem.
One on the things that fix a lot of problems is new plugs and plug wires but if you've already done that it will save us time and help with diagnostics.
It also helps in getting a conversation started instead of just throwing a question out to the forum.
Old 05 Sep 2009, 07:40 am
yes sorry about that m8 its a 2003 ltd disel model 2.2 i think its fitted with a unit from merc ..
its done 88k but not many services where stamped in the book when i bought the car..
it has ran no probs for the 6 months ive owned it ..
the engine light lit up last night so i got the codes from the ignition trick..
Old 05 Sep 2009, 07:55 am
OK,
With a diesel engine, you have an overseas (England, Euorpe?) model and they don't make them in the U.S. Apparently you also have a Turbo with the P0243 code.
Doing a search on this forum comes up with a wastegate problem. Maybe these couple of older posts can help you with yours.
Turbo Wastegate Solenoid 1
error code P0243
Old 05 Sep 2009, 08:13 am
many thanks for that and i will be searching them threads but is there any idea to what this code may be 1130
Old 05 Sep 2009, 08:43 am
Here's a Chrysler diesel with the same problem. Maybe it will help.
Another P1130 problem on Voyager 2.5crd - Chrysler Forum - Chrysler Enthusiast Forums
Old 05 Sep 2009, 11:12 am
many thanks
Old 05 Sep 2009, 10:02 pm
There's a UK PT Forum with lots of "tractors" (diesels).
UK Cruisers Club web site dedicated to the Chrysler PT Cruiser
