My 2003 PT Cruiser stalled on my wife the other day as soon as she put in into gear. Since then it refuses to fire up. I've gotten p0685 and p0113 fault codes from the odometer and it has me confused. I've replaced the crank and cam sensors to no avail. I've also switched out the asd relay. And also tested the coil pack and I have no spark. It has 93,000 miles on it. What other options could I have? Thanks to all that reply... Jim in Florida...
Jim,
I'm not home (Florida) now so I can't check the manuals but doing a search of your problem seems to point to a bad ASD relay.
Yes that's what I thought, however I switched out the relays., and I can feel a click on them when I turn the key to the on position. I basically moved the horn relay where I thought the problem was and got no results. Could it be a bad PCM?.. Thank you very much for your time.
Yep, sure could be that too but your going to probably need a scanner to check that out. My actual first thought was maybe your timing belt has gone. Not sure however if the engine would keep turning over when you tested it for spark. It's a non-interference engine so maybe it would turn with the starter since nothing is colliding.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 05 Sep 2009 at 02:15 pm. |
Yes the engine would continually turn over but woul not fire I have inspected the timing belt as best as I could without going crazy. and from the top the belt seems intact but a little loose. I'm at a loss of words. Evidently A new pcm is quite hard to come by and expensive, if it were to be the pcm. What would you recommend I do?.. Thanks very much.... Jim
Yea I think that's about my only option. I might try to find a identical pcm module at the salvage yard. and see what happens. All the multimeter test lead back to the pcm but it very well could be the timing belt. A mystery probably best suited for the dealership. But boy are they a riot. Thank you for your time.. Jim..
This sounds like an electrical problem. Most likely something is shorted somewhere. I would take it to a good shop or a dealer.
I thought PCM has to have VIN entered? You could try the coil - not often it goes, but hey...
Now I'm curious as to what it is...
Just want to follow up. I have a new development now. For the hell of it I disconnected the battery to reset the computer and then checked for the same fault codes. However it gave me a totally different one, it is now p0340 which signals a Camshaft position sensor circuit. Here's the catch at the beggining of this issue I installed a brand new csp sensor. So it must be something with the signal from the sensor to the computer. I've visually inspected the wiring harness, and see nothing out of the ordinary from what I can see. Does anyone have any imput? Thanks...
| spark plugs | ote69 | Turbo Performance | 28 | 11 Jul 2010 09:59 am |
| engine just shoots down riding !! then turns it again! suddeltly ! | grandcas | General PT Cruiser Discussions | 16 | 19 May 2009 08:03 pm |
| Another Spark Plug Thread... | vash382 | General Turbo Discussions | 11 | 07 Feb 2009 10:31 pm |
| Spark pulgs and spark plug wires? | balvarez814 | Tech & Performance Forum | 1 | 13 Aug 2008 08:16 pm |
| Ignition Questions....need help. spark plugs | ptcruzin42 | Tech & Performance Forum | 5 | 15 Mar 2004 08:39 pm |
