Coolant Drain & Fill Help
Old 05 Sep 2009, 02:41 pm
Default Coolant Drain & Fill How To
Drained out over a gallon, can only get 1/2 gallon back in thru the radiator cap.
What is the trick?
Thanks for any help. 2004 GT
Old 05 Sep 2009, 03:55 pm
Default Re: Coolant Drain & Fill How To
Found good answer here....... Only question I have - Is the engine off or running when fluid is being added and air bleeding thru the attached hose?
Gurgling sound under hood.....
To bleed the air from the PT system: (from Haynes Repair manual)
Attach a length of tubing to the coolant bleed valve, directing the end of the tubing into a container, then loosen the bleed valve.
Remove the coolant system pressure cap. Add the required mixture of new coolant through the filler neck until it reaches the pressure cap seat and a steady bubble-free stream of coolant flows from the bleed valve bolt. Tighten the bleed valve securely.
Add the same coolant mixture to the overflow reservoir until the level is between the FULL HOT and ADD marks.
Install the pressure cap and run the engine until normal operating temperature is reached, then allow the engine to cool. With the engine cold, add coolant as necessary to bring it up to the correct level.
Keep a close watch on the coolant level and the various cooling system hoses during the first few miles of driving and check for any coolant leaks.
Old 05 Sep 2009, 11:41 pm
dsmturbo's Avatar
Send a message via MSN to dsmturbo Send a message via Skype™ to dsmturbo
Thanks for the info
Old 07 Sep 2009, 10:11 pm
Originally Posted by dsmturbo View Post
Thanks for the info
Yea, glad I found the info - Seems peeps her would rather respond to why the rear windows won't roll all the way down - Than actually answer a question tech question in the tech forum anymore.
Rear window's
MOPAR ATF +4 Drain & Fill How Many Quarts? lmmegt Tech & Performance Forum 13 23 Sep 2009 07:30 am
pin hole leak at turbo's coolant line pppt03turbo General Turbo Discussions 1 21 Aug 2009 12:08 pm
coolant reservoir question pineapple Tech & Performance Forum 13 19 Aug 2009 07:02 am
coolant leak from the radiator drain geronimo Tech & Performance Forum 1 19 Jul 2009 02:55 pm
Coolant drain Chz Stage Turbo Kits 6 19 Aug 2003 02:58 pm
