...when adjusting the headlight alignment, which turning direction of the screw raises the light pattern and do both sides turn the same direction to raise or lower? What's the real story on what replacement bulb to use to get the brightest night driving lights without modifying the o.e. wiring harness??
I'm not sure about the adjustment, but as far as the lamps go, I have been using the Eagle 80 (9006) watt ultra white lamps in the Low beams, and the eagle 100 (9005)watt Ultra white lamps in the high beams. I am also using the Gold 65 watt (9006) lamps in the fogs, and am very satisfied with all. With these lamps there is no undue strain put on the wiring harness. Been runnin this setup since the 2nd day that I had the cruiser (1 year this month). Got them all from http://www.midnightmoose.com at a decent price too.
![]() Alan [} ]
GearHead,
What's up with Mopar trying to sell the Sylvania Silverstar bulbs for $27.00 a piece???? Direct from the Mopar website: PT Cruiser, 300M, Interpid, Grand Cherokee (00-03) P09006XSST $27.00 ea. Out of curiosity, how much did you pay for your bulbs? Has any of the plastic housing melted or deformed due to use? I have seen many cars "upgrade" to brighter bulbs, i.e.-more wattage and/or color. The housings do NOT stand up to the extra power used (and resultant heat given off). The PT keeps the Low and High beams on when in high-beam mode. Scott
\"If you choose not to decide, you still have made a choice.\" |
The headlight alignment is the very 1st question answered in the tech library at www.ptdiy.net
Answers to anything PT are already there for free! |
As far as higher wattage bulbs, some haven't had a problem, while others ended up burning/melting sockets, wiring, and had burn marks inside of the housing from the extra heat generated. Heavy duty Headlight Harnesses are available if you want to run 80w-100w bulbs. They are just plug in add-ons, include relays, and don't require any cutting/splicing of your current harness. ![]() They run about $43 including shipping: http://jen.liu.tripod.com/suvlights/id14.html Eliteshop on eBay sells 9005 and 9006 55w / 65w KÖBA Xenon bulbs for about $9 a pair plus shipping. They claim 4800K, which compare with OEM HP replacements SilverStars and PIAA SuperWhites and all the above are street legal. The 80/100W bulbs claim to have a 5500K rating, so it's up to you if you want the extra brightness (and heat). In some areas, you may be stopped and issued a ticket if the officer decides your higher wattage bulbs are blinding opposing traffic. Don't forget to apply some dielectric grease in the electrical sockets/connectors no matter which bulbs you decide to buy.
2002 Almond Pearl Limited Edition 27K It\'s nice to be important, but it\'s more important to be nice. http://sci-fi.ptenthusiasts.net/
Can we get away using 9006 bulbs in the headlights? The manual calls for 9006XS which has the connector straight out the back as opposed to the 9006 which the connector is at 90 degrees.Is there any interference issues or modifications needed for the 9006?
Been looking at brighter bulbs but a lot of places don't carry the "XS" version and when they do, it's at a premium price. Thanks
John & Terry ![]() "His" - 2002 Inferno Red Touring Edition "Hers" - 2003 Electric Blue Limited Edition Del Val PT Cruisers |
Sci-Fi,
Thanks for the info. Been seeing a lot of 9006 bulbs on eBay listed for the headlights and wondered what the deal was. Are the H-7 bulbs brighter than the 9006 bulbs? Thanks again
Have you tried one of the clubs in the UK and see if you can order it throug them - also I am going to england for Xmass and if you have the part number - I have inlaws there and a friend in Germany - Get the part numbers for the bulbs, Sockets and switch...
