Types of Antifreeze we can use???
  #11 (permalink)
Old 10 Sep 2009, 04:43 am
SRG SRG is offline
Default Re: Types of Antifreeze we can use???
You guys should try reading the owners manual:
From 2005 PT Cruiser Service manual:
CAUTION!
Mixing of coolants other than specified HOAT engine
coolants, may result in engine damage and may
decrease corrosion protection. If a non-HOAT coolant
is introduced into the cooling system in an
emergency, it should be replaced with the specified
coolant as soon as possible.
Do not use plain water alone or alcohol base engine
coolant (antifreeze) products. Do not use additional
rust inhibitors or antirust products, as they may not
be compatible with the radiator engine coolant and
may plug the radiator.
This vehicle has not been designed for use with
Propylene Glycol based coolants. Use of Propylene
Glycol based coolants is not recommended.
Adding Coolant
Your vehicle has been built with an improved engine
coolant that allows extended maintenance intervals. This
coolant can be used up to 5 Years or 100,000 miles before
replacement. To prevent reducing this extended maintenance
period, it is important that you use the same
coolant throughout the life of your vehicle. Please review
these recommendations for using Hybrid Organic Additive
Technology (HOAT) coolant.
When adding coolant, a minimum solution of 50% recommended
Mopar Antifreeze/ Coolant 5 Year/100,000
Mile Formula HOAT (Hybrid Organic Additive Technology),
or equivalent, in water should be used. Use higher
concentrations (not to exceed 70%) if temperatures below
34°F (37°C ) are anticipated.
Use only high purity water such as distilled or deionized
water when mixing the water/engine coolant solution.
The use of lower quality water will reduce the amount of
corrosion protection in the engine cooling system.
Please note that it is the owner’s responsibility to maintain
the proper level of protection against freezing according
to the temperatures occurring in the area where
the vehicle is operated.
NOTE: Mixing coolant types will decrease the life of the
engine coolant and will require more frequent coolant
changes.
  #12 (permalink)
Old 10 Sep 2009, 07:35 am
DexCool meets DaimlerChrysler MS-7170, MS-9769 requirements.
Prestone Exttended Life Antifreeze
The use of aluminum cylinder blocks, cylinder heads and water pumps requires special corrosion protection. Only Mopar(R) Antifreeze/Coolant, 5 year/100,000 Mile Formula (glygol base coolant with corrosion inhibitors called HOAT, for Hybrid Organic Additive Technology) is recommended.
Like I said - the whole issue is protection of the aluminum parts - DexCool does that wether your rig says PT Criuser on the hood or GMC.
  #13 (permalink)
Old 10 Sep 2009, 10:24 am
VNT's Avatar
VNT VNT is offline
Why use something from GM which is biggest crap antifreeze on the market in a Chrysler when you can either buy Mopar Orange or the HOAT G5 ???
I would avoid any antifreeze which is Universal and run the correct stuff to avoid all the grief.
Draft—DEX-COOL 2007, Part 1: Revising A Less-Than-Accurate Report
  #14 (permalink)
Old 10 Sep 2009, 10:59 am
Current formulation DexCool works fine for all vehicles. And it's what I have on hand so I use it.
They are both excellent products in their current formulations.
Would I run D/C HOAT if I had it on hand in my GM? Probably not since my 2008 Duramax truck is worth a bit more than the out-of warranty 2004 PT. Although I am sure the D/C HOAT would work in place of DexCool.
  #15 (permalink)
Old 10 Sep 2009, 05:05 pm
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Smile Re: Types of Antifreeze we can use???
I used the Zerex G5 ... I was told by the dealership if you flushed it all out, you could use dexcool, sorry if I mispelled.. I do not have much faith in them as they can not tell me what is wrong with my AC not cooling...AGAIN.... I would go with Zerex G5, only $10 at NAPA..
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
  #16 (permalink)
Old 10 Sep 2009, 09:04 pm
Matt42's Avatar
What you do is what you do. When I bought the 2001 at 80K miles, the independent garage had changed it to DexCool about 2 years earlier. I don't know if that included a full flush. The radiator was quite thoroughly clogged. Cause and effect? I dunno. Would I use DexCool? Not on a bet.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
  #17 (permalink)
Old 10 Sep 2009, 10:00 pm
Yada Yada.
Facts is, DexCool works just fine, just as good or better than any Chrysler product.
  #18 (permalink)
Old 11 Sep 2009, 08:36 am
tinosa's Avatar
Wonder if Dex-Cool was reformulated after GM agreed to settle?
Nationwide Settlement Reached In Gm/dex-cool Class Action Lawsuit - Law Firm Stueve Siegel Hanson, LLP Attorneys Kansas City, Missouri
  #19 (permalink)
Old 11 Sep 2009, 09:24 pm
Matt42's Avatar
Originally Posted by tinosa View Post
From the link:
The lawsuits were filed on behalf of owners of General Motors vehicles, which were factory-filled with "Dex-Cool" coolant. In summary, the lawsuits alleged that Dex-Cool degraded certain vehicles’ intake manifold gaskets and other engine sealability components, and that in certain other vehicles, Dex-Cool formed a rusty sludge, clogging the vehicles’ cooling systems and causing vehicles to overheat.
Fascinating. The radiator in my 01 was clogged with rusty sludge. But according to IMMEGT, I am obviously wrong. I stand corrected.
  #20 (permalink)
Old 12 Sep 2009, 03:07 am
Duster's Avatar
Don'y forget that Dexcool is OAT while Zerex is HOAT...
antifreeze mix gonzomania Non-PT Discussions 5 07 Jan 2006 08:46 am
Which antifreeze? OneBadCruiser Tech & Performance Forum 10 14 Nov 2004 12:44 pm
antifreeze smell????????? imjacked33 General PT Cruiser Discussions 6 28 Nov 2003 04:36 pm
Antifreeze PTGT Redman General Turbo Discussions 3 27 Sep 2003 01:21 am
