Types of Antifreeze we can use???
  #21 (permalink)
Old 12 Sep 2009, 02:08 pm
Default Re: Types of Antifreeze we can use???
"Antifreeze/coolant chemistries are different. Products that contain Organic Acid Technology (OAT) chemistry are NOT approved by Ford and DaimlerChrysler for HOAT/G-05 applications. Products using OAT chemistry may be damaging to cooling systems that specify Hybrid Organic Acid Technology (HOAT) chemistry based on OEM recommendations." per Valvoline (Zerex). In other words, don't use Dex-Cool.
  #22 (permalink)
Old 30 Sep 2009, 10:59 pm
shmexymedic's Avatar
OMG... so what is the conclusion? I have an 02... what do I need to get? lol I prefer to err on the side of caution so ideally, what are we supposed to put in there?
  #23 (permalink)
Old 30 Sep 2009, 11:01 pm
Matt42's Avatar
HOAT. It'll say so on the jug if it is.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
  #24 (permalink)
Old 30 Sep 2009, 11:42 pm
ok, got it, will look for HOAT... any brand as long as it is HOAT is ok?
  #25 (permalink)
Old 03 Oct 2009, 09:59 pm
Matt42's Avatar
Correct. Beware, though, as the sales person may try to tell you that the Dexcool will be just fine. They will especially do that if they don't have HOAT in stock. If that happens, go elsewhere, even if it is a dealer.
$20 more for the correct coolant vs. $400 installed for a replacement for a plugged radiator from using Dexcool. Hmm. Lemme think about this.
  #26 (permalink)
Old 04 Oct 2009, 10:42 am
Knotsobright1's Avatar
I would just like to add my personal experience with Dex-cool. When I purchased my PT it had 30,000 miles and the previous owner had drained out the system and put in Dex-cool. At 66,000 miles I started to have my own overheating issues and after much time spent on troubleshooting I found out I had a plugged up radiator. Now I have performed all services on this PT since I got it and the only thing that explains the LARGE amount of crap found in the radiator was from the corrosion that was caused by the Dex-cool.
Now I no there are other things that can cause there to be junk in the coolant but I checked and there is no other damage.
You can disassemble an entire PT with a 10mm wrench. So where did it go!
  #27 (permalink)
Old 01 Nov 2009, 03:25 pm
Napa Auto Parts, Behind the counter
Antifreeze, HOAT (Hybrid Organic Additive Technology)
Zerex Go5, made by Valvoline, Part Number: ZXGO51
$12.99 (not a bad deal when you compare to what the dealer charges)
  #28 (permalink)
Old 01 Nov 2009, 08:03 pm
I converted my 89 firebird to dex-cool, wanting to never ever have to do the water pump again and all. Within 40,000 miles, the whole radiator was completely clogged. I don't like dex-cool at all.
Zerex G-05 HOAT is available at the counter at Napa. Thats it. Used to be pepboys and autozone had it, but no longer.
  #29 (permalink)
Old 01 Nov 2009, 08:27 pm
DIYPTGUY's Avatar
Send a message via AIM to DIYPTGUY
Originally Posted by SRG View Post
You guys should try reading the owners manual:
From 2005 PT Cruiser Service manual:
CAUTION!
Mixing of coolants other than specified HOAT engine
coolants, may result in engine damage and may
decrease corrosion protection. If a non-HOAT coolant
is introduced into the cooling system in an
emergency, it should be replaced with the specified
coolant as soon as possible.
Do not use plain water alone or alcohol base engine
coolant (antifreeze) products. Do not use additional
rust inhibitors or antirust products, as they may not
be compatible with the radiator engine coolant and
may plug the radiator.
This vehicle has not been designed for use with
Propylene Glycol based coolants. Use of Propylene
Glycol based coolants is not recommended.
So basically is we dont use collant with Propylene Glycol we're ok basically? I use green prestone 50/50 prediluted. Says its safe to mix with any color coolant and safe for all cars.
My Love:
02' Gold PT Cruiser Touring: Pioneer DEH-P4000UB Reciever, Self built subwoofer enclosure w/pioneer TS-SW841D subs, Summit Turbo Muffler, Spectre Modular Air Intake, underseat neon lights, subwoofer neon strip lights, Intake Manifold Paint, exterior chrome trim, steering wheel cover.
  #30 (permalink)
Old 04 Nov 2009, 10:45 pm
thanks I was wondering what was the difference and what should be used on my PT Cruiser. I will be purchasing a gallon of zerex tomorrow!
antifreeze mix gonzomania Non-PT Discussions 5 07 Jan 2006 08:46 am
Which antifreeze? OneBadCruiser Tech & Performance Forum 10 14 Nov 2004 12:44 pm
antifreeze smell????????? imjacked33 General PT Cruiser Discussions 6 28 Nov 2003 04:36 pm
Antifreeze PTGT Redman General Turbo Discussions 3 27 Sep 2003 01:21 am
