My 77,000 mile, 2001, PT Cruiser has started leaking engine oil, passenger side. I run mostly short trips of 4-6 miles daily.
It appears that the rate of oil loss is about 1/2 quart per 3 week period. Cannot determine where leak is located as everyting is so tight around engine. Anyone with similar problem and solution? I am presently using full synthetic 10-30 oil and I'm going to change to regular 10-40 oil to see if it leaks less. Any comments would be appreciated. |
geronimo:
Thanks very much for reply and picture. Will check valve cover today. |
Leak not from valve cover nor oil pan below.
Plenty oil wetness coming from the back side of engine; alternator end. What about using an oil leak sealer such as: https://www.gouniversalproducts.com/...FVRc2god-jFZYA |
People have different opinions about liquid sealants. If they work, they work, but if you pour that in and it does't work, then you're in the same spot, oil leaking, but with that junk gumming up your engine. Unfortunately, leaks can spring from just about anywhere. I think we can find where this leak it coming from though.
Is the oil dripping to the ground, or getting spattered on other components? The oil filter is on the passanger side. It or your drain plug may have rattled open a bit.
2003 Touring Edition. 65k
Here's to a long life and a happy one. A quick death and an easy one. A pretty girl and an honest one. A cold beer and another one! ![]() |
The oil is dripping to the ground. There is a wet area on the corner, the lowest part of the engine block but no droplet is forming there, so it is a very slow leak.
It's impossible to see where it comes from due to the tight fit of the engine. My best guess is that it comes from the crankshaft oil seal. If it gets any worse maybe I should consider doing the timing chain replacement service. But at 77,000 miles it's kind of early. Do you agree? What is the latest milage for timing chain replacement? Thanks |
Camshaft seal sounds on. That oil leak sealant may be a good option to tied you over til you replace the timing belt. If that doesn't fix it, you might try adding some rtv sealant to any seems you can get to.
I agree 77k is early, however it has been done earlier (Timing Belt Replacement 70k .)Timing belt replacement is usually around 100k. Most get the water pump, and belt tensioner replaced while they're at it. Someone who's had it done can probably tell you a bit more if you're looking to do it yourself, but from what I've read, a mechanic will run between $800-$1,000 parts and labor. Go luck
Problem solved! No more oil leaks.
One bottle of this in the engine and the dripping stopped almost immediatly. First time in my life (65 yrs young) using any of these chemicals to solve leaking problem but, the cost of replacing camshaft oil seals is too high, for right now. When I change the timing belt I'll replace the oil seal. This is the product: Bar's Leaks Rear Main Seal Thanks for the help! Last edited by rcalzadilla; 25 Sep 2009 at 08:14 am. |
Glad that solved your problem and good luck with the PT.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Thanks for getting back with results. Good to know...
| Engine swap / replacement compatibility | Brent72 | Tech & Performance Forum | 2 | 28 Jan 2009 07:23 pm |
| Engine Replacement problems | LatinPhilo | General PT Cruiser Discussions | 7 | 28 Oct 2008 11:12 am |
| "Mysterious" turbo engine noise...??? | Gary04GT | Turbo Performance | 76 | 21 Aug 2006 08:28 am |
| Review: $2200 for a NA replacement engine PT | Ctown | General PT Cruiser Discussions | 8 | 24 Jul 2006 01:08 pm |
| AC oil leak | robinjoe | General PT Cruiser Discussions | 4 | 16 Sep 2005 03:38 pm |
