P0304 Success
Old 11 Sep 2009, 07:53 pm
Default P0304 Success
#4 misfire. Tore it apart today & it was a 2" section of gasket blown out at the bottom by #4 cylinder, lower manifold to head. Idles as smooth as new. Nice to post a solution & not a problem.
Thanks for all the advice. This forum rocks.
Old 11 Sep 2009, 11:16 pm
Default Re: P0304 Success
Congrats ! And thanks for posting the cure. If it isn't the wires/plugs, it's the intake gasket....
Old 21 Jun 2010, 04:36 am
Went through months of looking for the problem on this code.... finally found the intake gasket leak!! Seems it is not uncommon with the GT!!
Old 21 Jun 2010, 01:34 pm
And usually # 4 !
Old 21 Jun 2010, 08:44 pm
Dino's Avatar
Great news, thanks for sharing the fix, hopefully it will help the next guy
Old 21 Jun 2010, 09:24 pm
I have an '05 Dream Turbo H/O and we've changed the plugs and wires and also the PCV valve. Could this be our problem as we have noticed a small drop of "liquid" on the garage floor. Still showing the same 304 code and engine light is still on and has a miss? Can you provide us the needed info as to how you repaired your PT? Also, the cost? Is this something that needs to be repaired at the dealer or is it possible for the average mechanically inclined person to do?
Thanks, RT66
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
Check engine code P0304 Gary Mick Tech & Performance Forum 28 04 May 2014 06:26 pm
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
P0304 question 4SPEED Tech & Performance Forum 4 12 Apr 2008 04:51 pm
Zoo Cruise a Success PToholics Anonymous Southeast PT Forum 0 24 May 2004 09:01 am
