bad bad noise!!!
Old 19 Sep 2009, 02:13 pm
Default bad bad noise!!!
I have a 2006 PT and it recently started making a horrible sound from the accessory side of the engine,sounds like a seized bearing at times,and then a grinding sound,then nothing.Could it be the alt. or water pump or the tensioner?
Old 19 Sep 2009, 03:00 pm
Default Re: bad bad noise!!!
Front wheel bearing would be my guess. Take it to a good tire dealer like Les Schwab, they can diagnos, fix and align for much less than a stealership.
You bad noise......... You very, very bad noise.
Old 19 Sep 2009, 03:59 pm
not a wheel,car is not moving.
Old 19 Sep 2009, 05:00 pm
Matt42's Avatar
Could be any of the above. How many miles on the car? I've found that one of the local dealers, in business since 1927, costs about 10% more, but has a PT guy that gets it right the first time, and uses the correct parts. YMMV
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 19 Sep 2009, 06:23 pm
If you listen with the hood open, you ought to be able to pinpoint it.
Old 19 Sep 2009, 06:42 pm
Go to a aftermarket dealer and buy and install a good noise, that way it will cancel out the bad noise. Just kidding!!!!
Old 19 Sep 2009, 07:03 pm
Since we're all just taking a guess, it might be the compressor too. Was/is the air-conditioning working?
Old 20 Sep 2009, 08:24 pm
I'll have to check on the a/c pump but I think it is from the accessory drive.What would a turbo sound like if it was going?And hooligan,I'll check the price on the good noises,but around hear everything is at premium prices,lol.Thank you all for your input so far!!
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Tranny Noise??? Someone video diagnose? reklaweelmada Tech & Performance Forum 22 27 Nov 2009 11:52 pm
Misdiagnosed noise + smell + overheating Orionid Tech & Performance Forum 2 04 Apr 2009 11:04 am
?? Noise From The Front :( hicomp Wheels, Tires, Suspension 7 17 Oct 2008 02:36 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
