P0340 Code - Changed CSPS, stil not turning over
Old 19 Sep 2009, 03:57 pm
Default P0340 Code - Changed CSPS, stil not turning over
2004 Touring Edition (Not Turbo)
My Cruiser died in the middle of traffic early this week casuing me to have to tow it home. When trying to get it to turn over she acts like she really wants to, but never quite gets there. Pulled the codes and got a P0340 indicating Crankshaft Position Sensor problem. So, my wife went out an bought one this week. I slapped it in this afternoon (much easier job than I anticipated) and...she STILL isn't turning over. Check the codes agian - same code! I'm lost with what to do know! Where do you think I should go with this?
Thanks in advance!
Old 19 Sep 2009, 05:17 pm
Default Re: P0340 Code - Changed CSPS, stil not turning over
Most likely the timing belt broke. The PCM is seeing the crankshaft turn but not the camshaft. That's why it sets that code. Does it seem to crank kind of odd? Speeds up and slows down when you crank?
Old 19 Sep 2009, 05:40 pm
No, it really is more of a steady near turn over - sounds like it is just BARELY away from starting up, but doesn't make it. I haven't actually tried to turn it over for more an a couple of seconds at a time, but I would think that would be enough to hear the difference.
Alright - at the risk of sounding like a complete idiot - where will that be located and what would I be looking for to see if it is?
Thanks for such a quick response!
Old 19 Sep 2009, 06:09 pm
OEM or aftermarket sensor? Some aftermarket sensors do not work well to be able to operate. Did you disconnect the negative battery for about 5 minutes? There is a cover that can be removed, I think on the front of the engine that will uncover a opening about the size of a 50 cent piece, it is not easy to see in there tho. If I'm wrong someone will chime in and correct me.
BTW: Welcome to the Forum!!!
Old 19 Sep 2009, 06:18 pm
The sensor is a Duralast SU3019.
I had the negative terminal disconnected the entire time I worked on the vehicle. Habit - better safe than sorry.
Not sure what you are refering to with the 50 Cent size hole. What would be the purpse and what should I do with regards to it.
Thanks for the welcome! :
Old 19 Sep 2009, 06:30 pm
The cover and "peephole" is to look at the timing belt.
How many miles?
Old 19 Sep 2009, 06:45 pm
Oh - okay. Have to look when there is more light...
About 108k
Old 19 Sep 2009, 07:00 pm
Originally Posted by JMatthewM View Post
About 108k
You've just confirmed everyone's thoughts with that 1 answer. Timing belt should be chnaged (along with the water pump and a couple other items) at around 90-100,000 miles. Luckily it's a non-interference engine and you won't have internal damage.
Old 19 Sep 2009, 10:28 pm
I knew that code before I opened the thread - very common - does not cause cranking problems.
Our PT threw the code before 30K and it was the sensor - but the car still ran and drove - I replaced it myself.
Sounds like timing belt in your case.
P0340 cam sensor code in 2006 cruiser deighter Tech & Performance Forum 13 12 Jan 2012 07:41 am
2004 PT GT Stalls with P0340 code ron2004gt General Turbo Discussions 18 17 Apr 2011 06:46 pm
Error code P0340 ADVICE??? mjb457 Tech & Performance Forum 10 20 Aug 2009 09:24 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
code p0340 sflamedic General PT Cruiser Discussions 5 21 Oct 2008 06:12 am
