HELP! Check Engine Code
Old 22 Sep 2009, 07:28 am
Default HELP! Check Engine Code
Hey guys!
My 2003 pt cruiser has been having some trouble starting up lately. Whenever I go to turn it on it kind of stalls and makes a cli cli cli like sound. The check engine light is on, and I ran a code look-up today and it gave me the following:
P3044 and P3040
I tried looking in the previous check engine code threads and I can't find these anywhere, and i'm not sure if they mean the same as P0304? I am a girl, and don't know much about cars so take it easy on me! lol
my car has only got 54k
THANKSSS!!
Old 22 Sep 2009, 07:53 am
Default Re: HELP! Check Engine Code
The "cli(k) sound usually indicates a low battery. The starter takes more poser from the battery than anything else. At lease 11.8 volts. If you battery has run down or loses voltage while it sits to just below that level, the starter won't have enough power to turn the engine over. Free battery and charging system tests can tell you if the battery or alternator is in good shape. Take it to Pep Boys, Auto Zone, Discount Auto or just about any name brand auto store for a free check.
Old 22 Sep 2009, 08:16 am
Sure the codes were P3040 and P3044 and not P0340 and P3044?
P0340 Camshaft Position Sensor Circuit Malfunction
P0344 Camshaft Position Sensor Circuit Intermittent
I don't find a P3040 or P3044...
Old 22 Sep 2009, 08:28 am
I agree Don. Tried to find them and couldn't.
Old 22 Sep 2009, 08:42 am
And I agree the click, click, on starting is a low battery...
Old 22 Sep 2009, 12:24 pm
It's a sticky right here in the Tech threads ......
Error Codes
Old 22 Sep 2009, 12:28 pm
Immegt,
The highest number I see on the code list is 2501. Where do your see 3040 ???
Check engine code P0304 Gary Mick Tech & Performance Forum 28 04 May 2014 06:26 pm
Check Engine light code help sohc1996 Tech & Performance Forum 8 30 Sep 2012 07:36 pm
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
'Check engine light' code 0138 & 0139 1lowufo Tech & Performance Forum 4 01 Jun 2009 06:30 pm
CODE P0141?? CHECK ENGINE MEXICANPT General Turbo Discussions 0 08 Aug 2003 02:03 pm
