interference engine???????
Old 22 Sep 2009, 02:19 pm
Default interference engine???????
Is the 2002 PT cruiser (Non-Turbo) an interference or not??? I seem to be getting conflicting answers on the net about this question and it seems pretty straight forward to me.
Old 22 Sep 2009, 03:01 pm
Default Re: interference engine???????
All PT's are Non-Interference engines. If the timing belt breaks, the valves won't hit the top of the pistons but the valves can hit each other. 9 out of 10 cases there's no internal damage when the belt goes.
Old 23 Sep 2009, 08:08 am
As crewzin puts - it's not.
The valves will never strike the pistons, but whether they hit each other depends on a lot of different things. There doesn't seem to be a rhyme or reason to why one time when the belt breaks they hit each other, and other times they don't.
My wife's broke within 100feet after taking off at a light. Engine at about 3500rpm. Valves on cylinder 1 and 3 hit each other and bent (1 exhaust, 2 intake on 1, 1 exhaust 1 intake on 3). The head work and valves weren't too bad on the wallet, not too shabby for a rebuilt top end, was $800 total on top of the timing belt work.
Best way to tell is with a leakdown test, but a simple compression check will tell you if the cylinder is sealing, which it would not be if the valves touched.
Engine swap / replacement compatibility Brent72 Tech & Performance Forum 11 19 Dec 2013 09:18 pm
Engine Transplant BT7 General Turbo Discussions 5 14 Sep 2009 09:13 pm
NOISY ENGINE!!! ncrow02 Tech & Performance Forum 2 05 May 2008 12:52 am
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
