loose front end
Old 26 Sep 2009, 07:21 pm
Default loose front end
2002 limited with 74k. When hitting a bump front end sounds loose, but doesn't feel loose. Possible stabilizer links??????
Old 26 Sep 2009, 08:15 pm
Default Re: loose front end
Art,
Moved your post over to the tech section unless you only wanted the owners of PT from the mid-west to help you.
As far as what could be loose, worn or broken; there's loads of things on the front end that could cause your problem. Worn bushings, the tie rods, ball joints, stabilizer bar. Your going to have to get it up on a lift and have a good look to pinpoint what's loose.
Old 30 Sep 2009, 09:47 pm
with 74k
If never done, all bushings. Both my cars were shot by 50k.
Please help, front end shimmy survey Boomer Tech & Performance Forum 32 05 Oct 2009 01:54 pm
?? Noise From The Front :( hicomp Wheels, Tires, Suspension 7 17 Oct 2008 02:36 pm
New Front Strut Question Gottasmilealot Wheels, Tires, Suspension 3 21 Apr 2008 12:17 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
