Chassis Lubrication Points
Old 29 Sep 2009, 09:27 am
Exclamation Chassis Lubrication Points
Can someone tell me the Chassis Lube Points for a 02' base PT and a product recommendation (I've heard white lithium grease is best)???????
I have some creaking and "groaning" coming from under the car when I hit bumps. I had the car inspected at a ASE certified shop before I beought it. All the suspension components got a thumbs up so I'm pretty sure its in need of some lube. I live in swampy South Florida so humidity and moisture is a factor.
Thanks in advance!
Old 29 Sep 2009, 09:39 am
Default Re: Chassis Lubrication Points
You could try a good spray lube on bushings etc - But your PT ain't got no Zerks no how.......
tie rod ends
I like both of these for around the house and vehicles..... Door, hood, tailgate and fuel door hinges. Just sprayed some of the Tr-Flow Teflon spray on rubber garage door seals that were sticking to the metal doors after painting the house - problem fixed.
Old 29 Sep 2009, 09:49 pm
There are no real lube points. You can get grease in the balljoint on the control arms if they have been replaced. Replacement balljoints have a zerk fitting but you have to hold the grease gun to it. It won't hold itself like most zerks.
Lube Points? MCM Tech & Performance Forum 4 11 Apr 2010 06:57 am
Floor jack lift points? oldcoach General PT Cruiser Discussions 9 09 Feb 2010 04:57 pm
Lube points under PT Cajunsim Wheels, Tires, Suspension 5 22 Jul 2009 09:15 am
Floor Jack Points on PT rszappa1 General PT Cruiser Discussions 8 18 Oct 2004 07:58 am
BEST RPM SHIFT POINTS MEXICANPT Turbo Performance 8 08 Sep 2003 07:57 pm
