Added OEM Speed Control - Not working
Old 30 Sep 2009, 01:15 pm
Default Added OEM Speed Control - Not working
I bought an OEM Speed Control and installed it. I couldn't get the "Cruise" light to come on when I pushed in on the button on the end to the arm.
I called the service dept and was told that the 05's need the computer "flashed" for it to recognize there is now a Speed Control unit attached.
So I took it in and had them flash the computer. It still doesn't work, and they want another $127 to diagnose the problem.
I wanted to check all my connections first, before I pay again.....any suggestions on what to look for?
I read somewhere that there has been problems with the switch that attaches to the steering wheel being bad, but the parts guy could not find any info on that.
Any help or suggestions would be greatly appreciated!
Old 30 Sep 2009, 01:29 pm
Default Re: Added OEM Speed Control - Not working
There is a small vaccuum hose that attaches to the control unit on the passenger side - from underneath - if that comes off, no cruise - I had that....
Old 30 Sep 2009, 02:18 pm
But will having the vacuum home disconnected cause the "Cruise" light to not come on?
By the way, it is connected and there was vacuum present when I pulled it off the control unit.....
Old 30 Sep 2009, 02:28 pm
Someone said that you have to go to the dealer after installing all the parts and have thme falsh the computer so it will recognize that you have a new part.
Old 30 Sep 2009, 04:53 pm
He said the computer was flashed by the dealer...
Old 30 Sep 2009, 04:54 pm
Ooops, Missed that.
Old 30 Sep 2009, 06:52 pm
The PCM automatically detects the cruise control. Did you install the overlay harness? Some cars came ready to plug in and some not.... The directions show you the difference. If the switch is bad it can cause the same problem.
One more try... Cruise control not working... Jered General PT Cruiser Discussions 9 27 Jan 2009 03:04 pm
cruise control not working oldone Tech & Performance Forum 1 14 Oct 2007 09:50 am
Cruise Control not working glfnjim Tech & Performance Forum 14 27 Nov 2005 01:45 am
HELP- ADDED DUALS MPG WENT WAY DOWN 1MEAN PT Tech & Performance Forum 8 17 Jul 2003 08:37 pm
Added more chrome CREWZIN Testing 0 14 Jul 2003 04:18 pm
