04 turbo - jerking on acceleration
Old 02 Oct 2009, 04:22 pm
Default 04 turbo - jerking on acceleration
04 PT 2.4Lturbo. started jerking several months ago. showed P0344, so I replace cam position sensor. still jerking. I replaced plugs & PCV valve. little better..now only jerks after 15 - 20 minutes of driving. I was going to try plug wires next. It shows codes P0303, P0344 & P0551. Any help appreciated
Old 02 Oct 2009, 04:38 pm
Default Re: 04 turbo - jerking on acceleration
Welcome to the forum.
OK, not sure if you know what the other codes are but 303 is mis-fire in cylinder #3 and 551 is a fault with the power steering. Don't think that last one has anything to do with the jerking on acceleration.
Follow thru with your plans on some new plug wires and it just might end your problem with the jerking.
Are you taking off the negative battery cable for 5 minutes to clear any old codes?
Old 03 Oct 2009, 12:34 pm
Thought I did, but I will this time just to make sure. Thanks for the confirmation. Will advise after testing.
My car started jerking! helene Tech & Performance Forum 14 30 Oct 2011 09:58 pm
Jerking at low speeds, speedometer jumps Vas Tech & Performance Forum 3 29 Jul 2009 12:26 pm
PT Cruiser studdering/jerking oscar514 Tech & Performance Forum 4 28 Feb 2009 11:47 pm
PT Cruiser studdering/jerking oscar514 General PT Cruiser Discussions 1 28 Feb 2009 04:53 pm
2001 PT Automatic. Missing/Jerking during low RPM acceleration. Joshtalgia General PT Cruiser Discussions 13 14 Jul 2008 09:09 am
