A/C HELP
Old 02 Oct 2009, 08:04 pm
Default A/C HELP
my wifes pt cruiser a/c is running funny, when the a/c is turned on and the car is in idle, the car starts shaking and it blows warm or hot air but when its put in drive and it starts rolling it stops shaking and it blows cold air, even when the car is in drive but if we are stoped say at a light it will start shaking and blowing hot air. do any of you know what im talking about?
Old 02 Oct 2009, 10:35 pm
Default Re: A/C HELP
Yup.
Open the hood, and prop it open.
Start engine, turn on the A/C.
Go look and see if fan by radiator is turning - I bet it isn't.
If I'm right, you need a new fan.
Old 03 Oct 2009, 07:26 am
Old 04 Oct 2009, 10:01 pm
Matt42's Avatar
Originally Posted by quicksilverdon View Post
Yup.
I'm having pretty much the same problem with my 2004 Base that Garrambide reports. Should the cooling fan turn on even on a cold engine, when I switch on the A/C? The TSM for 2004 and 2001 imply that the fan wouldn't turn on until the coolant temperature reaches something close to fully warmed up.
I have a 2001 Touring to compare it to, which is handy sometimes.
2001: Cold engine, A/C on, fan is on. (PO replaced fan, so it's known good.)
2004: Cold engine, A/C on, fan is not on. Fan is OEM.
Suggestions appreciated. Even "What I said, dummy" will be useful and appreciated.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 05 Oct 2009, 03:25 pm
YES, the fan should come on when the compressor comes on even if the engine is completely cool.
Old 05 Oct 2009, 08:21 pm
Matt42's Avatar
I was afraid of that. I also checked it this afternoon with a fully warm engine, and it didn't work then, either. I was afraid of that also.
So it's a new fan assembly soon. I get to exercise my tools! Any suggestions on good aftermarket brands? Or brands to stay away from? And thanks!
Old 05 Oct 2009, 08:50 pm
If it's not a turbo, your in luck. Turbo fans are hard to find. If you deal with ebay, there's loads of fans available. If not you should be able to order one from a parts store (NAPA) or online from RockAuto.com. There's no brand names to look for or stay away from. You should be able to find the fan and shroud for around $100 plus or minus.
I put a sticky on top of the Tech and Performance section on how to put a new fan in.
Old 06 Oct 2009, 08:54 pm
Matt42's Avatar
Not a turbo, and the part's on order. (It's usually simpler for me to mail order a part, when I don't have the time to track one down at a parts store.)
And thanks for the sticky. Doesn't look too daunting.
