Battery Cables and terminals
Hey folks, 2 questions concerning replacement of my 2002 Non Turbo, bonestock, PT's Battery Cables:
1. Does anyone know the length of the Positive and Negetive cables I need to buy???? Adavnce has a few different lenghts that "fit" the car on their site. 2. Most important: Does anyone know where I can buy terminals that are Top Post but Angled at 90 degrees to allow the cables to drop straight down parallell with the battery side Thanks everyone |
Re: Battery Cables and terminals
Battery cables really don't wear out. Can't you clean them up? :lightbulb:
But for exact fit - go to the stealership parts counter......... :lightbulb: :dance: |
Take a string, hold it next to each cable, mark it, then measure it.
Chrysler sells the cable assembly as a unit, about $70 bucks if I remember correctly. It took about 20 minutes to do, unbolt the old one and put the new one in. srg |
My wife's PT, which I'll refer to as 'Hi Silver' from now on,
had the plus battery clamp half eaten away by the green gray corrosion. aaaa. This traveled an inch and a half down each red cable so what should have been a solid high amp connection was actually an intermittent dust clod. I carry with me battery lug crimps and tool so I got out of a jam with a post converter clamp. (still working two years later) My lesson on this with my PT, called 'Whitey', is that the slight investment in those round green and red anticorrosion pads for the bat posts absolutely prevent a lot of that. That little battery is in a confined and very hot spot. Since my filter box is cut away I no longer cover mine and keep it clean. I'm also big on spare parts, and battery is high on that list. |
Is the cable installation something that can be done easily in the parking lot? I won't be able to jack up the car at all, so I'll be limited to what I can reach while lying on the ground. And while I'm asking "basic" questions... what is involved in removing the air filter cover/etc to get access to the top of the battery? Looking at the shop manual (downloaded from a link on this site -- THANK YOU!) it seems simple, but sometimes what seems simple reading the manual isn't so simple in practice. Thanks in advance for your help. This site is an amazing source of info. -Tom H 2001 PT Cruiser 2.4L non-turbo |
You should have 2 "clips" that hold the cover down. one in the left side and one in front. Just push in the middle and with your thumb flick them off. They are fastened at the bottom so you don't have to worry about dropping them.
Never had to replace the cable, so I can't help you. |
$182 total; ouch. $80 for the part, and an hour of labor at $98/hr. Well, at least it is done. This includes positive and negative cables. Moral to the story -- keep an eagle eye out for battery corrosion; it can bring your day to a very rapid stop! -TH |
