Turbo and non turbo rad? difference?
Old 08 Oct 2009, 09:10 am
Default Turbo and non turbo rad? difference?
I have been having problems with an aftermarket rad. One broke,...replaced with another, which also broke at the bottom. (plastic bolt area near the drain.) I got fed up with the other place that did the original work,...and have it at another shop. This place did some research and says now that the radiator on it (broken one) is a different part number,....(my 03 is a turbo), basically a non turbo radiator has been put on my car. Would this be causing any problems.
Old 08 Oct 2009, 06:19 pm
Default Re: Turbo and non turbo rad? difference?
I know the turbo holds more coolant than a non-turbo - look up coolant capacities.
Makes sense since the turbo puts out more heat that it'd have a bigger radiator.
Old 08 Oct 2009, 07:45 pm
I was thinking the pressures are different as well.
Old 16 Oct 2009, 09:38 am
There was a difference, turns out my frame was bent up front, went thru two new rads to find out. Frame straightened,..seems good now.
Old 18 Oct 2009, 08:08 pm
Glad you found it.
Better have alignment checked if frame was bent...
srt4 vs pt cruiser turbo whats the difference ? rasputin General Turbo Discussions 2 24 Sep 2009 06:24 pm
Engine difference of 03 & 04 turbo? onedivinehammer Turbo Performance 2 22 Apr 2009 09:05 pm
Whats the difference in trannys from turbo to non? sknight88 General Turbo Discussions 6 13 Dec 2008 08:39 pm
Difference btwn Turbo & Non-Turbo Wheels tom-t-rifik Turbo Wheels/Suspension/Handling 6 12 Jun 2004 11:40 am
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
