engine oil pan swap
Old 09 Oct 2009, 03:09 pm
Exclamation engine oil pan swap
Hey guys, hows it going?
My '04 pt cruiser is in a desperate need of change of oil pan. I've tried all the methods to stop the stripped thread from leaking oil, all resulted in a destroyed oil pan with a 'mickey mouse' plug that is slowly dripping it self to death... I am on my way to purchase an engine oil pan for $50 and have all the necessary equipment to change it and parts as well (new gasket, oil etc..) however, I am missing the instructions on how to. So I am wondering if anyone has had the same problem as me, and had to change the oil pan and is able to share the knowledge of how to remove and reinstall the pan.. That would be greatly appreciated.. any form of help, links, pictures, step by step is appreciated!..
well off I go, and thanks ahead of time!
Old 12 Oct 2009, 02:56 pm
Default Re: engine oil pan swap
The only thing that I see is a special sequence in how you tighten the collar and bending strut. Sorry I don't have a link. Maybe some else does.
Old 13 Oct 2009, 07:32 am
Our pan had the same thing when we got it.I just drilled the pan out,tapped it for pipe thread and put in a 3/4 inch reducer.Been 14,000 miles since then and no leaks,simple fix
Tags
engine, leaks, oil, pan, replace
engine swap nimblemotors Tech & Performance Forum 10 01 Aug 2009 02:09 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
Complete Engine Swap TaylorMade General Turbo Discussions 35 05 Jan 2005 03:34 pm
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
