few turbo questions
Old 15 Oct 2009, 01:46 am
yteka99's Avatar
Send a message via AIM to yteka99
Default few turbo questions
I have a 2001 pt cruiser stock. I want to put a turbo on it but i really dont know anything about it. First, i dont know what kind of turbo i need. Second, i dont know if i need any other parts, prett sure i need an intercooler right? Third, how can i find one? I've looked on craigslist and found a few in my area but their off like civics and stuff like that. Third, i'm also looking to maybe put a new cam in it, any certain type i need that can run with a turbo?Any info please help!
rockin grampa's pt
Old 15 Oct 2009, 05:30 am
Default Re: few turbo questions
Welcome tho the Forum.
This has been discussed before, DON'T do it as the engine is NOT designed for a turbo. The Turbo engine had heavy duty components whereas the NA doesn't. Go to learn it or burn it website, lots of gearheads there.
Old 15 Oct 2009, 07:40 am
Here's some reading for you.
PTCrew.com - Learn it or Burn it.
If you do, keep boost low. The turbo engine was beefed up.
Old 17 Oct 2009, 10:42 pm
chris15's Avatar
Done a bunch of research on this and basically what it comes down to:
If you know what parts to look for, and you can do the install yourself, you can turbo the PT for about $1500 in parts. If you don't know what to look for and you take it somewhere to have the work done, expect to pay in excess of $3000.
The stock block is good for no more than 8psi, so you can expect to only see about 200whp without modifying the block. (Headwork, forged pistons, rods) If you have an auto tranny, that'll handle no more than 250whp, if you can get your motor to withstand it initially.
So, here's the age-old phrase I've come to hate: if you want turbo power, trade in your N/A and get a GT.
If you've got an 01 in good condition, you can expect to get probably $2500-3000 as a trade in at a dealership and probably find an 03 GT for (around) $6500-7500. That platform will give you what you're looking for, and you'd spend about the same amount just trying to max out your N/A PT.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
Old 25 Oct 2009, 08:06 pm
Not 100% accurate. You could trade in your N/A and get a Limited with a diet turbo and for less than the cost diff between a GT and a Limited - have more HP than the GT (I'm speaking of the Stage 0 upgrade).
Old 25 Oct 2009, 09:38 pm
chris15's Avatar
The comparison was meant to be made between the N/A and the turbo, not necessarily JUST the GT. I stand corrected, however, you also forget to mention (in that price difference) giving up the 17" GT wheels and tires, bigger front calipers, rear discs and the option to have the autostick tranny. And also, by referring to "Stage 0" on the Limited, I'm assuming you mean just the PCM flash, correct? If so, no. The Limited will match the output of a GT when the PCM is flashed, and Premium fuel is used, because that is the only thing holding the Lite beneath the GT. The only time that the Limited's output will exceed a "Stage 0" GT is with a Stage 1 installed.
2.4L Turbo questions airsierra General Turbo Discussions 4 12 Apr 2009 04:37 pm
Turbo N00B questions ucantcme General Turbo Discussions 0 13 May 2008 08:27 pm
Turbo brakes - questions quicksilverdon General Turbo Discussions 4 01 Jun 2005 06:30 pm
Turbo Cool down Questions nozzano22 General Turbo Discussions 11 01 Jul 2004 12:06 am
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
