PT Cruiser Forum Car Videos
Custom Wheels
Coolant Fluid Level
Old 28 Sep 2003, 09:59 am
Ed Lim Ed Lim is offline
Default Coolant Fluid Level
Yesterday I was refilling my windshield washer fluid, and I noticed the liquid in the engine coolant reservior was close to the "fill" line. The reservoir is a translucent container, with about a quart or two capacity, located just behind the engine near the firewall. The line above the "fill" line read "HOT". When you refill this, are you supposed to fill it to the "HOT" or in between? Or should I let the service dept. take care of it at the next oil change/routine service? (Shouldn't they be checking this anyway, along with the washer fluid? It says on the invoice that they do it.)[:I]
Perhaps I should look under the hood more often. It's been a few months since I did, but I really had no reason to fiddle around under there.
Old 28 Sep 2003, 11:47 am
MX-5 MX-5 is offline
Unless you have the newly available Zerex GO-5 Chrysler coolant with HOAT formulation, you should leave it to the dealer.
Zerex part number is ZXGO-51 with a line code ZRX if you have to order it. The gallon container is gold.
Refer to this post:
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=4031
Old 28 Sep 2003, 07:38 pm
Punch Punch is offline
the hot line is where the fluid should be when the eninge has been running at temp. for awhile.
vB code is On
I think my tranny's about to go! TaylorMade Tech & Performance Forum 25 01 Apr 2005 12:46 pm
Fluid coming out of exhaust... crazie.eddie General PT Cruiser Discussions 10 11 Nov 2004 04:21 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
Coolant drain Chz Stage Turbo Kits 6 19 Aug 2003 02:58 pm
  Remortgages | Credit Card Debt Consolidation | Personal Loans | News | Xecuter 3 Mod Chip
