Timing Belt Broke?
Old 28 Oct 2009, 10:06 pm
Default Timming Belt Broke?
Went to pick up my nephew and my 02 PT just did not sound right. When I got to his house I opened the hood and I could hear a little noise that sounded like it was coming from under the valve cover.
After I got him to his friends house I got some clunking sound from the engine. As I was limping it home the engine cut out and would not start. I went back with a code reader and got a camshaft position sensor code.
I am thinking the timing belt broke but why would you get noise before the belt broke? Wouldn't it just stop? What would it take to change out the belt? Would a valve hit a piston?
I just got the car back from the transmission shop a week ago. Cost me 2 grand for a rebuild. I hope I didn't just trash the engine.
Old 28 Oct 2009, 11:31 pm
Default Re: Timing Belt Broke?
WOW the same thing just happened to a friend, its in the shop now (cost $750). Good luck with yours!
Regards,
Qman...
Old 29 Oct 2009, 07:10 am
Did they put in a new tensioner? I heard there was a problem with them. Let me know how it works out. I am worried that a valve might be bent.
Old 29 Oct 2009, 10:22 am
cruserdad1976's Avatar
well the PT is a non interference engine so No the piston did not hit a value and since you were going slow i don't think the valves would have hit each other so you should be good on that end
from all i have found out it is between $1000-$1200 for a timing belt usually they do the water pump and the tensioners at the same time and for just a little more i believe they can do the oil pump also.
Im looking at changing mine OR maybe trading I just hate to pay that much for what should be a $400-$5000 dollar job
the noise could have been if the belt had started to come apart and was slapping the housing
The really sad part is there is nothing you can do to keep the belt in good shape it wil ware and at close to 90,000 it will need replacing that sucks
Old 29 Oct 2009, 01:17 pm
I have just over 90 on mine. Thanks for the help people..........
Old 04 Nov 2009, 11:58 am
Looks like it is the water pump. I noticed some water on the driveway under the timing belt side today. When I opened the radiator cap water came pouring out from under the belt cover. I guess the clunking noise was the pump falling apart. Could it be something else that went wrong in there?
If I use the kit below can I use the tensioner? It says first design. Wasn't there a issue with the tensioner that they changed?
GATES Part # TCKWP265B {Timing Belt Component Kit W/Water Pump; 4 Components (1 Belt, 1 Tensioner, 1 Idler, 1 Water Pump)}
W/Mech. Tensioner; 1st Design
Old 04 Nov 2009, 12:42 pm
Yes, there's a new, improved tensioner.
Old 04 Nov 2009, 04:58 pm
What was wrong with the old one?
Old 04 Nov 2009, 05:02 pm
it didnt hold up.. it usually broke and it was noisy
Old 04 Nov 2009, 05:15 pm
Duralast / Timing Belt Component Kit Part Number:
84143
Price:$271.99
Warranty:
1 YR Notes: Interference engine Water pump driven by timing belt. Kit includes camshaft belt tensioner. Camshaft belt idler. 3 plastic covers. Hardware. Kit does not contain belt. Retrofit kit
The above information is from auto zones web site
Is this the kit we need to switch over to the new tensioner?
Not sure about the Interference engine. Thought we had a non iterference engin.
what timing belt to use? 02ptlimited Tech & Performance Forum 1 12 Jun 2009 07:16 am
Could it be the timing belt? mbmouse Tech & Performance Forum 4 12 Jan 2009 09:01 pm
Timing Belt shaynebooth Tech & Performance Forum 2 31 Jul 2008 02:54 pm
Timing belt weighit General Turbo Discussions 22 05 May 2008 10:47 pm
timing belt Thomas1 Tech & Performance Forum 17 03 Jun 2004 04:28 pm
