Grinding noise front end 2002 woody
Old 29 Oct 2009, 12:57 pm
Default Grinding noise front end 2002 woody
At about 70k started with a front bearing noise when steering side to side. Then not only bearing noise but a clumping noise when on rough surfaces. Next a loud grinding noise making a turn, but went away.
The fix at 75k: left front bearing and hub replaced, lower control arms both sides, old ceramic brake pads ( 20k ) broke loose from backing on both wheels replaced with new ones, and last a front end alignment. $950.58 for dealer, and $70.00 for Sears alignment.
My local mechanic didn't want to do the job............
Last edited by Art Rigby; 29 Oct 2009 at 08:25 pm. Reason: add tie rod when doing alignment from Sears total at now $132.00
Old 29 Oct 2009, 07:05 pm
Default Re: Grinding noise front end 2002 woody
Thanks for posting with the cures. As I was reading I guessed wheel bearing & Bushings - they replace because it's easier than changing bushings....
2002 PT 2.4L Tapping noise mattcadu Tech & Performance Forum 3 01 Sep 2010 03:21 pm
AC Fan grinding noise shonenknife Tech & Performance Forum 5 20 Jun 2009 12:32 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
LF Wheel Grinding/Roaring Noise gmiller Tech & Performance Forum 4 23 Mar 2008 11:57 am
2002 Cruiser Noise Front Wheel? johnjsa Wheels, Tires, Suspension 4 11 Dec 2007 03:08 pm
