still working on starting problem. i have fuel pressure. iv retreved a code its p0340 witch comes up as a cam position sensor. iv changed the sensor and it still wont start. dose any one have the test procedures for the cam sensor.
Sorry to hear your having trouble.
P0340 is the "cam position sensor". It's working as designed. Basically the car is telling you the camshaft is not moving (either at all or not the way it should be). It is possible that the wires have frayed, search a bit and you'll find a couple cases of that. How many miles on the car? Hope this isn't a death knell for ya, but in my wifes 2001 base model, the P0340 was the only indication her timing belt had broken. It was throwing the code because the camshaft wasn't turning, because the timing belt had broken. The CPS is a hall-effect sensor, it senses a magnet on the end of the cam as it goes by. Your code indicates that it isn't sensing that. If you've replaced the sensor, its time to see if the cams are moving. |
Had a problem with my 02 not starting. The battery was fine, but when I hit the ignition, I only got a click... Took off the ginormous air cleaner and noticed the box that contained the relays (at the time, I was guessing it was the box containing the relays) Used the legend to find the ignition and starter relays,
and (at the tip of my mechanical game) tapped them a bit with my screwdriver... Starts every time now!!! |
| 02 wont start | Sfos | Tech & Performance Forum | 5 | 18 Oct 2009 07:49 pm |
| Wont start now? | morrisbeer | General PT Cruiser Discussions | 2 | 21 Feb 2009 10:14 pm |
| 07 TE PT wont start PLEASE HELP!!!!! | Norma | Tech & Performance Forum | 10 | 08 Dec 2008 08:58 pm |
| PT wont start anymore | master91599 | General PT Cruiser Discussions | 10 | 30 Nov 2007 11:42 pm |
| 01 PT cruiser wont start.. | EvilWRX | General PT Cruiser Discussions | 1 | 12 Feb 2007 02:35 pm |
