'05 making noise by front tire at slow speeds
Old 04 Nov 2009, 12:02 am
Default '05 making noise by front tire at slow speeds
2005 Chrysler PT Cruiser 4-Door Touring Edition - Automatic - 62,500 miles
A couple weeks ago my car started making some odd noises. It's hard to describe - at first I thought something was stuck up under the tire well - like a piece of paper or plastic garbage bag. It's a clicking/dragging sound that seems to come from the front driver side of the car near the tires. It only happens at speeds under 30mph (but more under 20mph) and it goes faster or slower depending on my speed.
Chhht - chhht - chhht - chhht <~~ the best way I can spell it.
It doesn't happen all the time and I've noticed it seems to happen when the weather is warmer (like in the afternoon when I go to lunch) or after I get off the highway after driving for 45 minutes or so. For instance, on Sunday, I went to run an errand at 3pm and it was quite warm that day (in the 80's) and the car made the noise right away. Later at 6pm when it was cooler it didn't make the noise at all.
Also - when it does decide to make that noise it doesn't matter if I am breaking, accelerating or coasting. It also seems to stop when I am making a sharp turn.
Boyfriend checked for anything stuck up under the tires and found nothing. He checked the engine for anything loose and didn't find anything loose. I tried to drive him around to let him hear it but, of course, I've only seen him at night and in cooler weather lately so the car's not done it in front of him yet.
Any help is appreciated!! (taking to the mechanic tomorrow or the next day)
Old 04 Nov 2009, 06:52 am
Default Re: '05 making noise by front tire at slow speeds
My hunch would've been brakes, but you say it doesn't change when braking?
Does your PT have hubcaps? On other cars, I've had a poorly seated hubcap make noise. Whack the hubcap with the palm of your hand all around (or a rubber mallet) and tighten the plastic bolts.
Old 04 Nov 2009, 09:48 am
I would have thought brakes, too. But, yes, it makes noise regardless of if I am using the brakes and doesn't get louder or quieter if I'm using brakes, accelerating or just coasting.
A conundrum!
No hubcaps either!
Old 04 Nov 2009, 11:32 am
Drive the car on ramps and inspect the rubber boots on the drive axles.... could be they are your culprit. Make sure the rubber isn't loose or torn.
Yes, an enigma...
Old 04 Nov 2009, 02:14 pm
I had a wierd one like this many years ago. It turned out to be the tire itself. The noise changed from a chht noise to almost a creak when going real slow. You can push the car in neutral with the engine off to hear it better.
Old 04 Nov 2009, 07:13 pm
I have the same noise in the drivers side front of my 05 convert, sounds like something is whirring around, it doesn't match the speed of the car or the engine. It sound like somehing hs been picked up by the drive shaft and can be heard at various times. I have 48K miles on my car.
I know it isn't a hub cap related sound because my car has cast wheels.
Jim
2005 Touring Edition Convertible - Inferno Red - Turbo lite
2010 Chrysler Sebring Soft Top - Silver
Firestone Firehawk GT Tires, chrome door handle and trunk latch cups, chrome headlight, back-up light and tail light trim, chrome grille overlay and antenna bezel.
Who said this was a "chick car" ?
http://s5.photobucket.com/albums/y16...t=P1010026.jpg
Old 04 Nov 2009, 07:31 pm
Matt42's Avatar
Possible causes:
1. Lousy brand of tire.
2. Damaged tire starting to separate. Get on top of this right away. Did you hit a curb recently?
3. Loose wheel cover or wheel cover nut. (This would stop at 30+ MPH due to centrifugal force.)
4. As mentioned above, damaged CV joint boot. How many miles on car?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
Old 04 Nov 2009, 07:56 pm
hmmm - I hope it's not the tires. They are relatively new (almost a year old) - but they are not a great brand, that's true. I'd expect them to last more than 12,000!
Matt - car has 62,500 miles on it. Pretty average for an '05, I think.
I'll bring all of these points up to the mechanic. Maybe a good starting point for him.
Old 04 Nov 2009, 07:57 pm
Or maybe I do hope it's the tires! That would be a relatively easy fix! HAHA!
Old 06 Nov 2009, 12:13 pm
Tires come with a warranty? Most have something, but they always "pro-rate" and doesn't seem to help much...
Tire noise front end..... AZCruiser26 Wheels, Tires, Suspension 5 19 Sep 2009 02:14 pm
Scratching noise at highway speeds? futureman General PT Cruiser Discussions 31 05 May 2009 03:28 pm
my door locks are making a noise jerrylk Tech & Performance Forum 1 02 May 2009 10:13 am
TIRE NOISE OR SOMETHING MORE SERIOUS?? mjb457 General PT Cruiser Discussions 8 26 Mar 2008 03:17 pm
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
