'06 A/C fuse & relay location?
Old 08 Nov 2009, 01:27 pm
Unhappy '06 A/C fuse & relay location?
I have an '06 PT Cruiser that the A/C compressor apparently stopped working... I have tried looking for the fuse in the power distribution unit in the engine compartment; nothing there references the A/C system (no fuses are blown anyway). I also do not know where the compressor relay is.
Can anyone help?
Old 08 Nov 2009, 02:31 pm
Default Re: '06 A/C fuse & relay location?
For some reason ($$$) MaMopar decide to do without the a/c relays in 2006. All major circuitry was wired into PCM and if anything a reflash by the dealer could be the repair. You could first start with disconnecting your battery for 10 minutes restart....This will reset your PCM if the problem lies there. But the culprit is more likely a compressor failure or the low and high comp. clutch switches failed on the compressor. There is also a a/c pressure cycling switch but when that fails it usually alternating warm to cold air.
Not sure but either the low or high comp. switch is easily replaced, the other requires discharging the freon from the a/c system.
Good Luck, 66CUDA
Old 21 Feb 2010, 12:40 pm
txcruiser's Avatar
FlaKeysMac, see my post here about the same problem:
UPDATE.. Totally Intergrated Power Module needed
2006 Headlight Fuse Location aea_1962 PT Cruiser News and Rumors 13 18 Nov 2010 07:52 pm
window fuse location? imaram2 General PT Cruiser Discussions 6 02 Feb 2010 01:37 pm
Fog Light Fuse- Location? MissRixatrix Tech & Performance Forum 5 11 Oct 2009 03:54 am
Where is headlight relay fuse om 06 PT Touring outfit Exterior Accessories Forum 4 08 Feb 2009 07:08 pm
Hello and Please help with Fuse location DelValPC Tech & Performance Forum 2 01 Jul 2008 02:28 pm
