Timing belt changeout questions!!!
Old 10 Nov 2009, 02:01 pm
Exclamation Timing belt changeout questions!!!
Hi all. I have a '02 base model with no mods. I am about to change out the timin belt as I have 90K miles. Here's my questions:
I was planning on changing T-belt, T-belt idler, and T-belt tensioner as well. I came across this kit of PartGeek.com
02 2002 Chrysler PT Cruiser T-Belt Tensioner Kit - Engine Mechanical - OES Genuine - PartsGeek
Does anyone have any experience with this? Its going to cost me an extra 100bucks. Whats the benefit?
Old 10 Nov 2009, 02:36 pm
Default Re: Timing belt changeout questions!!!
Your buying a new timing belt cover which isn't really necessary. The old one can be modified just a bit to go over the new (changed in 03) tensioner. I had asked my mechanic about the new cover before doing the job and he said not to bother.
P.S. You might also want to change the water pump while doing the timing belt. They do wear out and it takes the same amount of time to take everything off as the timing belt does so might as well do it while you have every thing off.
The serpentine and alternator belt (while they can be changed separately) also has 90K on them...while your doing the rest.
Old 12 Nov 2009, 05:03 pm
mjb457's Avatar
Guys( I did ask this before) is 90K the number where is should be changed... (owners manual says 2 things-one 90K other 105K) again thanksMJB
Old 12 Nov 2009, 05:32 pm
Don't think there's an exact number but we've been telling everyone that it should be changed around/before 100K to be safe.
Old 12 Nov 2009, 05:35 pm
cruserdad1976's Avatar
well im getting into that area as well what about the oil pump????? is it a good idea or just a added expense
Old 12 Nov 2009, 06:10 pm
There's only one person that I've ever read about on this forum that recommends the changing of the oil pump. Got to admit that I didn't think about having mine changed when I did the belt but took all the other recommendations on the water pump, serpentine and alternator belt and tensioner.
Old 12 Nov 2009, 07:29 pm
After reading numerous timing belt threads, I have not seen any different advice for new models like my 08. Is the tensioner coming from the factory still of poor quality? Or is there a year it was finally upgraded?
Charliehorse
2010 Classic in Deepwater Blue w/Grey Interior
2008 Bullitt Mustang #901
Old 12 Nov 2009, 07:32 pm
It was upgraded in 2003.
what timing belt to use? 02ptlimited Tech & Performance Forum 1 12 Jun 2009 07:16 am
Timing Belt questions dehcho Tech & Performance Forum 7 02 Dec 2008 12:22 am
Timing Belt notadodge Tech & Performance Forum 11 25 Nov 2008 09:37 am
Timing Belt shaynebooth Tech & Performance Forum 2 31 Jul 2008 02:54 pm
timing belt Thomas1 Tech & Performance Forum 17 03 Jun 2004 04:28 pm
