Lights flickering when brakes applied?
Old 12 Nov 2009, 06:53 pm
Default Lights flickering when brakes applied?
I've been noticing that when I have the light on that when I hit the brakes and the brake lights come on the head lights flicker. Is this just normal or is something else to blame?
Thanks
T
Old 13 Nov 2009, 09:29 am
Default Re: Lights flickering when brakes applied?
There have been many posts about headlight flicker - here and at PTCrew.com - Learn it or Burn it.
Some things:
Battery on it's way out?
Battery cables tight and clean?
Some have found adding ground cables helped (get pre-made ones at AdvanceAuto, etc, and go from - lug of battery to motor or chassis, or both).
Old 13 Nov 2009, 03:23 pm
It sounds like you need a new battery. Replacing the battery should solve your problem.
Jim
2005 Touring Edition Convertible - Inferno Red - Turbo lite
2010 Chrysler Sebring Soft Top - Silver
Firestone Firehawk GT Tires, chrome door handle and trunk latch cups, chrome headlight, back-up light and tail light trim, chrome grille overlay and antenna bezel.
Who said this was a "chick car" ?
http://s5.photobucket.com/albums/y16...t=P1010026.jpg
Old 13 Nov 2009, 03:25 pm
Battery starts the car fine and seems ok...?
Old 16 Nov 2009, 11:02 am
The battery will start the car OK, when you increase the load on the electrical system, AC, headlights, windshield wipers, radio, etc, the headlights will dim when you press on the brake pedal and the tail lights come on.
My 2001 Vette did the same thing, replacing the battery solved the problem. Your battery is getting weak and will not handle the entire electrical load. Take it to one of the auto stores and ask them to load test the battery, if the battey is losing power, it will show up during the test.
Replacing the battery should solve the problem.
Jim
Old 22 Nov 2009, 11:17 pm
Quicksilvers on the right track. I had the funky flicker too - The biggest effect was to add a 4AWG wire from negative directly to the chassis, drill a new hole, scuff it all up and put a ring terminal and nut/bolt combo in. I.E. increase the wiring to the chassis of the car.
Darn good advice - if its really old and starting to sulfate it's voltage is dipping and bringing down the electrical system with it. Any parts store does these tests for free - part of selling you a battery and all.
Old 23 Nov 2009, 01:05 am
Been going on since the PT came out. Doing a hyperground fixed mine. Can buy a kit or DIY. If DIY use 8ga wire from a stereo shop and gold ring connectors. Pretty easy to do and a lot cheaper than a kit.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Flickering lights again white General PT Cruiser Discussions 1 02 Mar 2009 04:00 pm
2007 Dashboard lights flickering Frouge General PT Cruiser Discussions 6 05 Jan 2009 02:03 pm
Flashing/Flickering lights alien88 General PT Cruiser Discussions 4 25 Nov 2008 10:19 pm
lights flickering cookieman18 General PT Cruiser Discussions 16 13 Mar 2008 09:10 pm
Headlights flickering when brakes depressed? TripleJackInGA General PT Cruiser Discussions 3 12 Jul 2003 06:52 pm
