Okay here we go again.2006 Pt Touring non turbo. My AC stoped blowing cold air. My compressor doesnt even kick on and now to make matters worse the car is starting to overheat... There is power going to the compressor, and it is new.. Also what type of relays are the acc fan?? I know they are 12v 40 a, four prong, now will any type of relay do?? Lets just say the parts people around here are not to bright and the mechanics just want to run up the bill with out fixing the problem... Is there something I am missing with the compressor?? What about the wires that connect to the compressor in the back, High pressor sensor is new also along with the switch on the accumalitor.. I am beating myself in the head here. To recap, no cold air---- compressor wont kick on--- starting to overheat-----.. Any help would be nice... I am up for looking at anything here or trying
2006 PT Cruiser Touring Non-Turbo 3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy1 -Hyper White 921 Superstar Bulbs from Autolumination 1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination Pioneer Head unit W/ HD & Satellite radio 2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests HID Lights 8000k 9006 for lows from xhidoutlet.... HID Slim 55w 6000K for high's from HIDGEEK .
outfit,
Overheating and no cold air have only one thing in common that I can think of ...the fan. If the fan isn't working properly things heat up to the point where the compressor might have blown out some of the R134 which causes the sensor to see that your low in pressure and stop the compressor from coming on. I actually have an A/C problem myself that just started where it's not blowing as cold as it usually does and the compressor goes on and off every 15-20 seconds, BUT it's not overheating (fan IS working). I should be just a little low on the R134, will find out this morning. Check to see if the fan is coming on in your PTwhen the A/C is turned on. Turn the car on in the morning when the fan won't come on, then turn the A/C ON. The fan should start turning. You can't hear it as it's only the low speed and it's hard to see.
On my 2006 (base PT) the high speed fan kicks on when the a/c is turned on or when engine cooling is needed as operating temp. increases. I can definitely my fan every time its on. It is a replacement cooling fan. Mine blew out at 36.5K... Just out of warranty. Cost me 200.00 including labor. My buddy only charged me 50.00 for labor. Its not a hard swap out that you can't do yourself. If you take your time maybe 3 hours or so. Similar to what CREWZN stated...sounds like your cooling fan stopped causing your compressor to maybe run hot or a fuse/relay to go bad. I don't think your compressor is bad.
Good Luck, 66CUDA |
the pt's have a two speed fan with two relays and four brushes, as happened to me the high speed brushes wore out and I only had one speed, the a/c has a temp sensor and works together with the two speed fan to keep the system cool, no high speed=irratic a/c. went through this with an 07 after recharging the system three times, dealer wanted like 450 bucks for this fan!!
Same thing on my 06 Touring. Had the fan and relays replaced at the dealer. Like new ever since.....
2006 Pt Touring - daily driver 2003 Road King with too many add-on's |
| OVERHEATING!!!!!! | spidy134 | General Turbo Discussions | 14 | 10 Feb 2012 07:34 pm |
| overheating | earle | Tech & Performance Forum | 67 | 04 Oct 2010 06:49 pm |
| overheating | missejd1963 | General PT Cruiser Discussions | 3 | 03 May 2009 08:39 pm |
| 2001 PT Touring Edition - Overheating problem | Rowarken | Tech & Performance Forum | 2 | 09 Sep 2007 09:26 am |
| Is this overheating? | MEXICANPT | Turbo Performance | 6 | 31 May 2004 06:32 pm |
