Oil Pressure Sending Unit
Like Tree4Likes
Old 23 Nov 2009, 11:17 am
Talking Oil Pressure Sending Unit
Hi all savvy PT'erz!
I had to replace our Oil pressure sending unit/switch this weekend because it was causing an oil leak. I just wanted to give everyone some tips.... It is very hard to try to reach the sensor from under the car. What we did was we removed the battery, air box, we also moved the fuse box aside just a bit to get more room to work (not necessary though). After removing/moving those parts we had plenty of room to work with. Simply disconnect the electric connection and remove the sensor with a socket. The part was $11.99 at Kragen with a lifetime warranty! (not just a dealer only item :]) The socket isnt a special socket its just a 27mm ($9.99) deepwell. I hope this helps someone, overall the job wasnt hard so no need to pay anyone to do it for you! :]
Old 23 Nov 2009, 07:29 pm
Default Re: Oil Pressure Sending Unit
Is there a difference if it is a turbo?
Old 24 Nov 2009, 12:44 pm
Im not sure, I should have mentioned ours is a N/A PT. Ill see what i can dig up.
Old 24 Nov 2009, 07:19 pm
Just did mine last week on my base PT. If your arms are long enough, you can access it top passenger side and reach wayyyy down and you won't have to remove anything! Its good to put her up on ramps to get and idea where it is, then take her off and do the repair. You forgot to mention unlocking the electrical connection by pushing the slide lock to the side. Just curious, what year and mileage on your PT?
66CUDA
Old 25 Nov 2009, 11:09 am
Our PT is a 2004, 140K miles
Old 10 Dec 2009, 12:42 pm
Greetings to all.
Just found this forum after searching for PT Cruiser oil sender leak.
My wife's 2007 is leaking from the sending unit.
39,000 miles, just out of warranty. grrrrrrrrrr
Anyway, thanks for the great information.
Old 12 Oct 2011, 01:08 pm
Does anyone have a picture of what this is supposed to look like, i've had a problem with this damn leak for a while now. first they thought it was the corner of the pan, then they said it was a pinched seal on the oil filter, now they are at the point where they believe it is higher up, some type of oil pressure switch. I'm assuming that this is what is being discussed on this forum. just want to make sure before i start taking things apart.
Thanks,
Anthony
Old 28 Oct 2011, 01:47 pm
Gremlin's Avatar
Originally Posted by apalomo01 View Post
Does anyone have a picture of what this is supposed to look like....just want to make sure before i start taking things apart.
Thanks,
Anthony
Oil Pressure Sending Unit Wire
Take note that it Should take a 27mm socket to get it off but mine ('03 GT) took a 26mm, and a 27mm for the replacement.
It should take you no more than about 5 minutes to replace it... and the part is less than about $15
Update: The 27mm was too big, 26mm too small, 1 1/16th inch perfect fit!
White '03 GT. Mine since 2010. DIY work (read, budget): DIY cabin air filter, ball joint/control arm bushings/wheel bearing replacement, CV axle replacement, brakes, struts, K&N drop-in filter, oil pressure sensor replacement, Spark plug gasket replacement.
"But I don't want to go among mad people! Alice remarked. Oh you can't help that, said the cat, We're all mad here. You're mad, I'm mad. How do you know I'm mad? asked Alice. You have to be, or you wouldn't have come here, replied the cat."
Old 05 Jun 2012, 04:02 pm
Turns out the real problem is the Cam Seals have gone bad, i can see oil on the teeth of the timing belt when i look through the cover. Can Anyone tell me the difficulty level on replacing these seals?
Old 05 Jun 2012, 05:21 pm
not sure, but when i took mine in for the timing belt, water pump, etc they called and asked if i wanted the cam seals replaced as well for an additional $14.
hopefully you won't have to go with the whole tb procedure just for that.
oil pressure sending unit mowerman Tech & Performance Forum 11 29 Oct 2009 12:10 am
How do you know if it's a bad pump or sending unit? scrisp2 Tech & Performance Forum 4 18 Nov 2008 08:44 pm
Electric Oil Pressure Unit Paw General Turbo Discussions 6 15 May 2005 04:48 pm
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Oil Sending Unit rockycruiser General Turbo Discussions 9 15 Oct 2003 11:30 am
