Need help quickly
Old 26 Nov 2009, 08:12 am
Exclamation Need help quickly
I am new to this Forum but need some help please. I recently moved to Belgium and to pass the inspection, I have to lower my passenger headlight. I have found where to move it horizontally but not vertically. Can anyone help me please.
Old 26 Nov 2009, 08:40 am
Default Re: Need help quickly
I just read over the Chilton and Haynes manuals and they say only to use the single adjusting screw under the turn signals for all the adjustment that you need.
Old 26 Nov 2009, 09:51 am
From sticky above
Service Manual for the 2003 PT
http://webdev1.net/hosted/documents/...shopmanual.pdf
Chapter 8L
LAMPS/LIGHTING - EXTERIOR
Interestingly, it shows export models with the capability of adjusting the verticle alignment from inside the cab.
Old 27 Nov 2009, 02:55 am
I do appreciate your comments so quickly. I do have an American specs PT but you are correct, the European versions do have headlight adjustments in the cabin. As for the manual, mine states that only horizontal adjustments are possible with the adjustment screw located underneath the headlight. Thank you very much for your replies, it is very much appreciated.
QUICKLY PLEASE, Front Door Speaker Size, what will fit like the Factory Speakers????? MoparHemiPower PT Cruiser Convertible Forum 8 06 Aug 2009 02:37 pm
Getting Off the Line Quickly bemo Tech & Performance Forum 12 23 Mar 2008 07:45 pm
Texas Cruiser Expo Deadline Is Quickly Approaching ptmyway Gulf PT Forum 2 10 Apr 2005 09:42 am
Need Help QUICKLY SwtNLwPT General PT Cruiser Discussions 14 25 Mar 2004 09:21 am
