slow starting
Old 28 Nov 2009, 03:26 pm
thumperz's Avatar
Default slow starting
during my 5speed swap,i moved the battery to the rear,and now its starting really slow,but i also picked up a 622 code too,which is an alternator problem. ive never moved a battery to the back before,so is it just the alternator thats causing this,or the lengthen'd cable?
Old 28 Nov 2009, 06:18 pm
Sharkstooth's Avatar
Default Re: slow starting
When running a battery in the trunk,you will want to have thicker battery cables.Then make sure you run a ground wire from the engine to ground on the frame in the front a one from the batt to the frame in the back otherwise you good have slower cranking power.I have done this to a few of my street cars in the past and didn't have any problems.Good luck.
Old 28 Nov 2009, 10:17 pm
Welding lead makes good battery cable , available in various sizes , go big then run it inside pvc pipe...
This Black Thing Keeps Chasing Me
YES ! That is a Ron Paul for President Sticker..
Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood
Ed Sidders , Lake-O The-Pines , Northeast Texas
Old 29 Nov 2009, 12:38 am
Agree with the others.
Length = resistance, so you need heavier gauge wire.
have slow leaks too alycemaysk@aol.com Wheels, Tires, Suspension 12 13 Sep 2012 04:48 am
My car is slow!!! Konkeler General PT Cruiser Discussions 10 05 Jul 2004 07:43 am
Slow moving! renichms General PT Cruiser Discussions 6 22 Apr 2002 08:09 pm
