Error codes that aren't critical.
Old 30 Nov 2009, 10:43 pm
Default Error codes that aren't critical.
I've had two codes for many years that I just live with.
They are 0601, and 1684.
These are internal ECM circuits malfunctioning.
I had thought that the logic chip controlling the engine light turn on function is at fault?
Car has normal MPG and never skipped a beat all these years, it's an 01.
Should I not be worried?
Old 01 Dec 2009, 06:12 am
Default Re: Error codes that aren't critical.
Read this - P0601: it MAY be covered under emissions warranty
OBD-II Trouble Code: P0601 Internal Control Module Memory Check Sum Error
1684 - should not stay - maybe you should check you battery cabl connections
1684 - The battery has been disconnected within the last 50 starts.
Old 01 Dec 2009, 11:20 pm
Thanx for this info.
I did just put a battery in her.
The 0601 reflashing may be worth a try.
Having the engine light on this car bothers me.
2 error codes granty Tech & Performance Forum 7 05 Sep 2009 10:02 pm
no error codes lt4supr Tech & Performance Forum 4 14 Aug 2009 07:34 pm
i got error codes what do they mean feefeethaflee Tech & Performance Forum 3 31 Jul 2009 08:41 pm
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
