Serpentine belt change
Like Tree6Likes
Old 02 Dec 2009, 01:57 am
yteka99's Avatar
Send a message via AIM to yteka99
Default Serpentine belt change
I drive an 01 pt and i need to change the serpentine belt. I got an extra belt but when i went to change em out it seemed like i had to move pretty much everything to get to it. Is there an easy way to do it?
rockin grampa's pt
Old 02 Dec 2009, 07:52 pm
Default Re: Serpentine belt change
The only things that need to be moved are the passenger front wheel/tire, inner fender and the drivebelt splash shield. At least that's the way to do it for a 2001.
The automatic tensioner must must be released to allow for the belt replacement. Place a wrench or socket on the tensioner pulley bolt and rotate it clockwise until the belt can be removed.
The Haynes or Chilton manual (under $20 each) explains it all.
Old 02 Dec 2009, 07:56 pm
yteka99's Avatar
Thanks but i literally just changed it 20 mins ago ha. I was told that my drive belt was the serpentine.
rockin grampa's pt
Old 03 Dec 2009, 07:13 am
Yes, the serpentine belt is also called the drive belt. That's why I called it the drivebelt in my answer. So you posted looking for an easier way to do it after you already did it? Nice one gramps.
Old 04 Dec 2009, 04:52 pm
yteka99's Avatar
I thought the drive belt was the belt on top of the motor? I had to change the belt that connects to the alternator. I wasn't planning on doing it i went to my uncles house to ask him when would be a good time and he said lets do it now ha. But what is the belt on top called? It's got a plastic piece around it and i think its next to a motor mount. I'm not sure if its a motor mount though. It's behind the radiator cap.
rockin grampa's pt
Old 04 Dec 2009, 05:26 pm
Are you talking about the timing belt? On the end of the engine?
Old 04 Dec 2009, 06:10 pm
yteka99's Avatar
I think so. I dont have a photo editing program s i cant make a good picture.
rockin grampa's pt
Old 04 Dec 2009, 07:33 pm
Timing belt
Old 22 Oct 2011, 09:36 am
does anyone know or have diagram for timing marks for 2007 2.4 pt cruiser
Old 15 Apr 2014, 04:23 pm
thecabinguy's Avatar
Maybe, Crewzin, you can help me. I am seeing all sorts of posts on how to replace a serpentine belt but not one about about WHEN. My '05 PT has 82,000 on it and I know it's never been replaced. Any ideas?
Power Steering Pump & Serpentine Belt? ChicagoPT Tech & Performance Forum 4 24 Apr 2009 10:51 pm
Changing a 2007 Cruiser Serpentine Belt falconut Tech & Performance Forum 6 20 Mar 2009 08:43 pm
Serpentine Belt Pulley Alignment marty Tech & Performance Forum 2 28 Dec 2008 08:11 am
Timing Belt change calflan Tech & Performance Forum 1 23 Oct 2007 03:52 pm
New serpentine belt already? RJ General PT Cruiser Discussions 4 07 Sep 2004 08:12 am
