Engine Won't Turn Over
Old 05 Dec 2009, 03:46 pm
Question Engine Won't Turn Over
At first, I thought it was a bad battery.
Firestone installed a new battery for me and it still won't turn over.
One of two things....
Timing Belt--94,000+ miles on current belt--hoping and praying that is what it is.
Or Engine is losing compression....which I am told can be costly...don't quite understand what losing compression means or what would cause it and why it's such a high ticket item to fix. Any explaining would be much appreciated. While I am a computer and math geek, mechanical stuff is a mystery to me.
Old 05 Dec 2009, 06:34 pm
Default Re: Engine Won't Turn Over
So, starter turns but engine doesn't catch?
Engine light on? Should be. Turn key on off three times and get codes in the odometer area - they are clues.
Ask around - try auto parts stores - for a mechanic - when you here the same name twice - try them.
How was car before the problem? Running okay? If so, doubt lack of compression, and lean toward timing belt - you're at the mileage when they go.
Compression is the pistons coming up and compressing fuel/air mix to ignite it - lack of compression is caused by worn rings (seal the piston to inside of cylinder) or valve problems - very rarely will lack of compression mean car won't start - just lack of power.
Google "otto cycle" to get a good idea of how engine works.
Old 05 Dec 2009, 06:39 pm
It tries to turn over but won't. The battery was bad....$129 to get a new one installed.
It ran fine most of the time....idled rough at times like at the drive through...sometimes at traffic lights...
Old 05 Dec 2009, 07:17 pm
You're not clear - starter turns or not? Unless the starter turns, timing belt can't be your problem.
The rough running is probably plugs and wires - ever have them changed?
You didn't reply about check engine light - is it on?
Old 05 Dec 2009, 07:23 pm
Unhappy Re: Engine Won't Turn Over
the lights that come on when you turn the keys light up
the engine tries to turn over but won't starter is turning--cranks but won't start tries to start but won't---sounds like my old Ford Escort did when its timing belt went out
plugs and wires have not been changed...
I am mechanically challenged
Old 05 Dec 2009, 07:49 pm
Then timing belt is a good bet.
If the place you have it at now gave you that "low compression" crap - take it somewhere else.
By all means have plugs and wires done with timing belt.
Also get accessory belt done - save you a visit later.
Old 05 Dec 2009, 07:53 pm
Uh btw, what do spark plugs do
what does an acessory belt do
at intervals, the digital read out on the Radio/clock go out and the horn stops working...all other stuff including radio/cd player continue to work
Old 05 Dec 2009, 08:05 pm
I was gonna jump in Don but it's getting too technical for me.
Old 05 Dec 2009, 08:13 pm
A lot of it is too technical for me.
Now, if it was computer programs like MS Office, then I'd be handy as can be.
Ronda
Math and Computer Geek
Old 05 Dec 2009, 08:27 pm
Use the search engine of your choice.
Will not turn over warnockdonald Tech & Performance Forum 12 31 Dec 2012 03:12 pm
dome light doens't turn off till i turn on the car... realized Interior Accessories Forum 3 15 Jul 2009 06:44 pm
Turn Will not turn PT 2002 WanttoPimpthePT Tech & Performance Forum 19 09 Jul 2009 12:43 am
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
My turn to ask for help CREWZIN Exterior & Interior Styling 5 29 Sep 2003 10:57 am
