please help!! no spark on number 1 and 4 cyl.
Old 12 Dec 2009, 03:40 pm
Send a message via MSN to coco1476
Default please help!! no spark on number 1 and 4 cyl.
I really need some help for this problem. I have a 03 pt none turbo 80 000 km automatic tranny. First the battery went dead for no reason, gave it a charge try to start it nothing on the starter, checked the fuse and it was burnt, changed it got it to start but it wasn't running on all 4 cyl. so i changed the plugs, still the same, checked for fire on the wires and number 1 and 4 nothing, changed the coil and it still the same, i swapped the relay with the horn relay and nothing changed. I did check the connection at the coil with the key to on and there is 10.70 negative volts on the two external wires and the wire in the middle has 0.22 positive volts. The car starts fine but has no power at all and it's only running on number 2 and 3 cyl. Please i need your advise.
2004 pt none turbo
Old 12 Dec 2009, 04:40 pm
Default Re: please help!! no spark on number 1 and 4 cyl.
This is about a turbo but maybe it will help...
Need no start help for 04 turbo!!
Old 12 Dec 2009, 10:38 pm
Did you replace wires with the plugs? Sure would point to coil - I know coil fires 2 plugs at once - you see nothing (voltage-wise) on 1 + 4 ever?
Old 13 Dec 2009, 05:59 pm
Teekypt's Avatar
Send a message via Skype™ to Teekypt
F.Y.I.
Error Code P0304 Cylinder 4 Misfire Detected
2003, GT, "ShuggaPlum", xenon bumper kit, custom grey/black CoverKing seat covers (front & back).
Sunrise: July 2002
Sunset: June 2018
http://www.math.uh.edu/~tai/Today/Clean3.jpg
Old 22 Dec 2009, 02:58 pm
Thanks guys but nothing seems to be working, 2 days ago the car had being sitting for 3 days and jumped in it and it started really good and ran like it suppose to left it running on idle for about 2 hours and everything went good so i went for a drive, after 15 minutes it started to do the same thing again. Its like i was out of gas and after a minute or two, it was running on 2 cylinders again. Could there be something in the gas tank or the fuel filter is blocked or even broken inside?? I would really appreciate help cause i don't have money to bring it to a garage. Thanks everyone.
2004 pt none turbo
Old 24 Dec 2009, 01:52 am
I just found out that there is spark on every plug and i think it's missing gas after i rev it at 2000 rpm in neutral for about 3 minutes the car starts to stumble so bad and stalls that it's like it is running on 2 cylinders but its running on all 4, it's just missing gas could it be the pump or the filter? when it stalls on its own i put the key to on 2 or 3 times letting the pump to stop before putting it back to on the car starts fine with no trouble but if i rev it again for 3 minutes at 2000 rpm it starts back to stumble and stalls. Anybody knows what could be wrong with it?? Thanks
2004 pt none turbo
Old 24 Dec 2009, 08:41 am
Well, filter is by the pump, and with the labor involved, I'd hit both - but put some fuel system cleaner in first - can't hurt to try.....possible you had a trace of water that iced in gas line.
Old 24 Dec 2009, 11:34 am
You need to pin down whether this is a spark problem or a fuel problem. Since you now suspect a fuel issue, the next step is to test the fuel pressure at the fuel rail. The book calls for 53 to 63 psi at idle.
Old 24 Dec 2009, 02:16 pm
Presure is one measure, flow is another. He can have enough pressure, but not enough volume.
Need Help With OEM part number csd PT Cruiser Convertible Forum 8 05 Nov 2011 10:21 pm
platinum Number pt4cec General PT Cruiser Discussions 4 24 Mar 2009 03:41 pm
Need a part number! skokz Tech & Performance Forum 1 17 Sep 2008 06:57 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
vin number Capt Kidd PT Cruiser Convertible Forum 0 06 Apr 2004 04:40 pm
