02 pt died and won't crank over
Old 15 Dec 2009, 11:13 pm
Default 02 pt died and won't crank over
Engine shuttered and died, turn key- won't even try to crank! Can't get codes to display in odometer (it almost always comes up with at least one code). Actually- the gauges look kind of dead (even fuel gauge) Battery is almost new. Acts like if you tried to crank it without depressing the clutch pedal first. Possible PCM fuse? Not sure where the PCM fuse is located (the manual is in storage 'cause we just got done moving (figures!). Disconnected batt-to reset- no go. Tried pushing and popping clutch- didn't start. Some folks rumor about an "engine lock-out" system???? This silver baby is sitting in Lowe's parking lot tonight...any suggestions greatly appreciated- and as usual...cold weather in the forecast!!
Old 16 Dec 2009, 01:02 am
Default Re: 02 pt died and won't crank over
I too believe that it won't crank over. I tried pushing and popping clutch- didn't start. Some folks rumor about an "engine lock-out" system???? This silver baby is sitting in Lowe's parking lot tonight...
turbo
Old 16 Dec 2009, 06:38 am
Not much to go on -
Stuttered and died - did you have lights on? Did lights go dim? Could it be alternator?
You try hooking jumper cables to another car? I'd try that first.
Oh, and don't anybody click the link in post above mine - a Spammer...
Old 16 Dec 2009, 08:04 am
ChefTank's Avatar
its the alternator... And it drained your battery
^^^ all of this guys post just repeat what others have said in the threads
Spammer alert!!!!
Get lost you terd herder no one wants your cheap chinese shit your trying to sell
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 16 Dec 2009, 08:53 am
Battery is fine, lights strong. Praying a fuse somewhere has blown. I don't have schematic to trace back starter system, but something has "pulled the plug" on that circuit. But for fact that pop starting it didn't work...there's more to this than just the starter circuit.
Old 16 Dec 2009, 09:29 am
Starter wouldn't cause car to stutter and die.
Old 16 Dec 2009, 09:42 pm
Chrysler mech suggests eliminating the "clutch safety switch" and "neutral start switch" first. That's where we're heading, along with checking main power cabling. Gauges all ok now. Need schematic for those switches (I refuse to buy yet another Haynes manual as I know it's in a box somewhere around this place!) We're towing this part-timer tomorrow 'cause it's freaken cold outside up here in upstate N.Y.... 11 F. Really bothering me that computer code won't display...just the miles.
Old 17 Dec 2009, 06:58 am
Again, don't see "clutch safety switch" and "neutral start switch" causing it to stutter and die - starting, yes.
I'm thinking fuse or wiring. What got gauges working?
Do you get "done" when you check for codes?
Hope it isn't computer....
Old 17 Dec 2009, 09:53 pm
Safety switches both check good. I'm getting convinced the ignition circuit is bad somewhere, or like you suggest..a fuse. I'll quickly swap the interchangeable relays just to eliminate them (ignition/ run relay?) I'm thinking the codes are not coming back 'cause the computer isn't seeing the on/off on/off on" from the key? (and no "done" statement like you're asking- good point!) Can a fuel pump failure cause ignition circuit to lock out? (like no pressure- no go!)
Old 18 Dec 2009, 09:10 am
There have been way more ignition switch failures than fuel pumps - you have a lot of junk on key ring? Some have pushed in on key & got it to work, but that's just temporary - ignition cylinder isn't a major expense.
Ignition switch would also explain why it died - shut engine off....
Maybe tech could jump around switch to see if that's it?
01 PT with cam/crank code problems dcrider81 Tech & Performance Forum 21 22 Jul 2009 09:58 am
Bell crank bf4cm28 Wheels, Tires, Suspension 3 22 Mar 2009 05:07 pm
Bell crank Back order steelheep General PT Cruiser Discussions 0 02 Dec 2008 09:58 pm
Crank Scraper LAF Turbo Performance 0 18 Jan 2004 06:29 pm
Cold Crank, 2nd Try. zzzhuh Turbo Performance 10 11 Jun 2003 10:45 am
