PT Cruiser Forum Car Videos
Custom Wheels
grease fittings
Old 06 Oct 2003, 12:39 pm
RickMe RickMe is offline
Default grease fittings
Mechanic recommended putting grease fittings
in new PT Cruiser ('02). What do you say?
Old 06 Oct 2003, 01:13 pm
Grouch Grouch is offline
Not necessary might do more harm than good if some idiot puts too much grease in and blows the seals. Most cars built in he last 10 or 15 years haven't had grease fitting witch makes me wonder what decade your mechanic is stuck in
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
Old 06 Oct 2003, 05:43 pm
Sci-Fi Sci-Fi is offline
Believe the snapped off grease fitting is also an indicator of when to replace the ball joint. Here's a quote from the service manual:
"DIAGNOSIS AND TESTING - BALL JOINT
With the weight of the vehicle resting on the road wheels, grasp the headless grease fitting. With no mechanical assistance or added force, attempt to move the grease fitting. If the ball joint is worn, the grease fitting will move. If movement is noted, replace the ball joint."
Old 07 Oct 2003, 06:27 pm
MX-5 MX-5 is offline
Page 2-2 of the 2003 service manual:
STANDARD PROCEDURE - LUBRICATION
There are no serviceable lubrication points on the
front suspension. The front lower ball joints have
grease fittings which have had the head snapped off
by the manufacturer after they have been filled. This
has been done to eliminate the possibility of damaging
the non-vented seals. Grease will not leak from
the broken grease fittings. The ball joints are sealed
for life and require no maintenance.
CAUTION: No attempt should be made to replace
the ball joint grease fitting with a new fitting, then
filling the ball joint with grease. Damage to the
grease seal can result.
Your mechanic must have stopped his training and education about 10 years ago.
I own a shop and am Master ASE certified. You must keep up with new designs and technology.
Don't grease the ball joints. They are not designed internally to accept more grease.
From page 2-13:
LOWER BALL JOINT
wheels, grasp the headless grease fitting as shown
(Fig. 18). With no mechanical assistance or added
CAUTION: No attempt should be made to service
the headless grease fitting on the ball joint. It has
been purposely snapped off by the manufacturer to
avoid over-greasing.
That info is right from the maker of the PT Cruiser.
vB code is On
RE: Grease kennybopaloo General PT Cruiser Discussions 4 21 Nov 2005 12:03 pm
Compression fittings on terminals 2step Sound and Security Forum 4 15 Jan 2005 05:02 pm
Grease Spots? CHROMEDCRUISER The Detail Shop 4 10 Sep 2004 03:57 pm
grease fittings RickMe General PT Cruiser Discussions 1 07 Oct 2003 06:23 pm
compression fittings? Punch General PT Cruiser Discussions 4 02 Oct 2003 12:59 pm
  Gas Electricity | Debt Help | Loan | Facebook Proxy | Debt Help
