'01 PT is over heating
Old 16 Dec 2009, 07:22 pm
Default '01 PT is over heating
Iím at my wits end. My poor 2001 PT is over heating. The fans working, it was replaces near end of the warranty.
I changed the thermostat and everything was good for a time ,then it over heated again. I flushed with a cleaner but found a crack in the plastic upper radiator tank. Replaced with a new radiator .
Still over heats running IN PARK . The only thing left is the pump. Itís been my experience a water pump usually leaks when itís going bad. Iím guessing itís not circulating and it over pressured the radiator causing it to rupture. One thing I did notice is the engine strained a bit once and the belt squeaked for a time. I need some ideas/input. Iím thinking replacing the water pump is to hard for a shade tree guy like me. Help!
Old 16 Dec 2009, 07:35 pm
Default Re: '01 PT is over heating
Ususal causes - thermostat, flush, fans - you've covered...
Are you losing coolant? Is oil and coolant clear (sign of head gasket is milkiness)
Another cause is radiator cap - suggest one from dealer as aftermarket is hit or miss.
The water pump is driven by timing belt. How many miles? The timing belt needs to be changed at 100,000 miles (many say sooner) - and it is always recommended to do water pump at same time - which means it does wear out.
Price for timing belt and water pump is around $750 - some have paid less,many have paid more - dealers are $1,000 or so.
Some have done it themselves, but it isn't easy.
There are write-ups, but it's tricky to get it aligned properly.
Old 16 Dec 2009, 09:05 pm
72,000 Miles had major tune up @ 60,000. No discoloration in fluids. I suspect radiator cap as well, I ran the engine with cap off at idle it started erupting as it heated up, donít know if thatís normal. Another thing is from cold to heat up with cap on, fluid shot out the reservoir
Old 16 Dec 2009, 09:22 pm
Not a good sign.
Did you bleed it to get air out?
heat - defrost problems
Sounds to me like either head gasket, clogged radiator, or pump...
Old 17 Dec 2009, 11:33 am
No. I just added coolant. How can you bleed the air? It's no my first radiator swap on a car, never had to bleed the air before. Iíll check today maybe itís settled out. If not Off to the shop it goes. I'm having PT withdrawals.
Thanks for the help.
Old 17 Dec 2009, 01:40 pm
On the thermostat housing there is a bleed off valve, open it until fluid comes out. Close, start car, crack it open until fluid comes, you may have to do that a number of times. Good Luck, some where on this blog there is a picture provided by Crewzin that shows the valve. It was just on here within the last couple of days.
On wife's pt when it was overheating I had pump (and belt) replaced and still overheated. my mechanic ask if losing fluid but the overflow tank stay at the mark. bad cap was the cause and then the petcock started to leak so those could be the culprit. also like quicksilverdon said these cars seem to be prone to air in system.
Old 17 Dec 2009, 02:44 pm
It's in the linked thread that I posted above...
Old 17 Dec 2009, 02:48 pm
You guys are a great help. I just came in from checking out the air thing. Soon as I started it up with cap off it gurgled up air. So I start stopped it a few times and did add more coolant. But the gauges went nuts.
??? And everything died. Wouldnít do anything Itís has new battery. Had to reset computer and started right up. I can hear gurgling from the system. Was able to drive round the block. Temp goes up than back down. Just maybe need to work air out. Getting new cap today. Donít know what the shut down was all about?
over heating thehairguy Tech & Performance Forum 1 30 Aug 2009 03:51 pm
Over heating Cowboyfann General PT Cruiser Discussions 1 10 Jun 2009 02:43 pm
Back with another over-heating prob... Deano Tech & Performance Forum 2 24 May 2009 03:56 pm
Car over heating fan not tuning on tvguy56 Tech & Performance Forum 3 05 Mar 2009 01:39 pm
O gee! !!!!! my PT is over heating!!!!!!!!!!!!!!!! Ctown General PT Cruiser Discussions 8 03 Jun 2006 07:07 pm
