How do I get to the starter? 2003 PT 2.4L
Old 19 Dec 2009, 02:19 pm
Default How do I get to the starter? 2003 PT 2.4L
Hello all! I'm having problems with my 2003 PT. It's not starting up, just clicking once. I've read quite a bit about the possible causes and I am now ready to test a few of them. However, I have trouble locating the starter (I do know approximately where it is), and even after I do find it, I will need a way to get to it with the car still in once piece.
What I want to do is try to establish electrical connections straight from the battery to the starter, bypassing the car cables, to see if it's a wiring problem. So I've got some jumper cables and a masters degree in engineering, but how do I reach the starter terminals without taking the whole car apart?
Any help would be great!
Old 19 Dec 2009, 03:32 pm
Default Re: How do I get to the starter? 2003 PT 2.4L
Hooray! I found the starter (the descriptions were far too complicated), but there's still half of the car in the way, and the jumper cable clip does not fit through whatever gaps there are. Any ideas?
Old 19 Dec 2009, 06:46 pm
Just a click is nearly always a sign of weak battery or dead starter (starter solenoid).
Old 20 Dec 2009, 09:04 pm
I'd load test the battery first. It is easy to do at the auto parts store. Next easiest is to check both ends of the battery cables for corrosion. If you wiggle them you might get a start which would tell you the cable is probably bad.
Finally, would be the starter. Sometimes a rap to the starter body, on the metal part not too hard will move the contacts inside the starter to a 'good' spot. Not a fix but let's you know where the issue is.
cant remove starter garciaag Tech & Performance Forum 21 11 Jul 2012 06:09 pm
remote starter superpug666 General PT Cruiser Discussions 7 09 Dec 2008 09:47 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
Starter Setup PTmodrod Tech & Performance Forum 2 29 May 2008 06:04 am
Remote Starter for 03 GT Indynick General Turbo Discussions 6 22 Dec 2004 03:44 am
