Overheating issues
Old 21 Dec 2009, 04:30 pm
Default Overheats while driving, cools at idle
My 2004 PT overheats when I drive but cools down when I idle. I have replaced the thermostat about 7 months ago. What would cause this? The fan seems to be working ok -- not sure how to test the fan though. Any experiences with this issue?
Jk
Old 21 Dec 2009, 04:54 pm
Default Re: Overheating issues
Check thru the "sticky's" in the front page, one of them pertains to the cooling fan.
Old 21 Dec 2009, 06:33 pm
Your overheating problem is opposite than most overheating problems because it gets hot when your driving. The fan turns off over 35mph as the air into the radiator is enough to keep it cool unless it's an internal problem. Look for signs of head gasket failure. Loss of fluid, milky fluid in the oil. Or, possibly a clogged radiator where at idle and slow speed, the small amount of water flowing is enough to keep it cool but at higher speeds the blockage might not be letting enough water to circulate and it overheats.
Old 25 Jun 2012, 09:36 pm
My 03 had the same issue, shop went as far as telling me it was a head gasket. Because of the info provided on this forum, I got second opinion and found out it was a clogged radiator.
Long story short, check everything and anything
2005 PT Cruiser Overheating Issues! EnRAM Tech & Performance Forum 12 01 Aug 2016 04:54 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
Newbie here; same PT issues Wienerdog General PT Cruiser Discussions 11 04 May 2009 11:57 pm
2 Issues - Need Help 07PTSilver General PT Cruiser Discussions 2 09 Dec 2008 03:45 pm
Cruiser AC Issues mscaho Tech & Performance Forum 4 16 Jul 2007 11:20 pm
