Changed timing belt now have bad gas milage
Old 23 Dec 2009, 11:33 pm
Default Changed timing belt now have bad gas milage
Hello, I have a 2006 PT cruiser non turbo auto trans 51,000 miles, I have a engine stumble, shaking at idle. I had my plugs and wires both after market changed and it didnt help, then they told me to change my timing belt, I did that and still the same thing but now my cruiser is eating alot more gas, can it be that the timing is off? I have paid over $1000.00 and still have the same trouble that I started with, can anyone help, I dont want to keep paying for repairs that dont help. Thanks
Old 24 Dec 2009, 09:11 am
Default Re: Changed timing belt now have bad gas milage
Welcome to the forum!!
When did the stumble start, before or after plugs & wires? If it was after, I would suspect wrong gap, it should be gapped at .040. Otherwise IDK!!!
Old 24 Dec 2009, 09:17 am
Welcome.
I don't know who told you to do timing belt - I've never heard of one going bad at 51,000 miles. I have over 82,000 miles on my PT now and am planning to have the belt done in the future...
Does it run okay off idle?
You may have an intake gasket leak - spray starter fluid along seam of intake gasket while engine is running - if idle smooths out, it's an intake gasket.
If timing belt wasn't put on right, car would be hard to start and really run crappy.
Another possibility is a clogged injector - try putting some good furl injector cleaner in the gas - sometimes that works.
Timing belt weighit General Turbo Discussions 27 26 Dec 2012 06:49 pm
timing belt Thomas1 Tech & Performance Forum 20 21 Jul 2012 09:06 am
Help! I got my timing belt changed and I'm getting like 10mpg less now!!! 85_305 Tech & Performance Forum 20 26 Sep 2009 11:03 pm
Could it be the timing belt? mbmouse Tech & Performance Forum 4 12 Jan 2009 09:01 pm
125K Miles.. getting timing belt changed this weekend - what else?? realized General PT Cruiser Discussions 4 16 May 2008 09:38 pm
