Does not start (no ignition / electrics OK) - HELP!!
Old 28 Dec 2009, 11:58 am
Default Does not start (no ignition / electrics OK) - HELP!!
Hi,
I live in the UK, and I've got a PT Cruisher (2006 - Auto - 2.4 - 28,000miles). It's been -6 Degrees (very cold for the UK!) and the car started fine, it's been on the drive for a few days and worked fine - but today (0 degrees) it will not start (no ignition or clicking, as if it is dead) at all with the key turned in the ignition.
The electrics seem to be OK (lights on dash, remote locking, headlights all light up OK) - the battery has also been checked and charged OK and I've attempted to 'jump' the car with leads - but it still will not turn over and start? HELP!!! Any ideas????
Old 28 Dec 2009, 05:05 pm
Default Re: Does not start (no ignition / electrics OK) - HELP!!
Welcome.
With a "jump", you've ruled out battery.
Ignition switch?
Starter?
See if you can put 12V directly on starter to rule that out.
Old 28 Dec 2009, 05:27 pm
Have someone turn the key to the "start" position while you take a meter and check for 12 volts on the small wire at the starter motor. If you have voltage at this point, everything up to the starter is OK...the starter/solenoid will have to be replaced. If no voltage is present, more troubleshooting is necessary...something in the start circuit (ie- ignition switch, starter relay, etc.) is bad. Be careful when troubleshooting around a starter motor...in case the vehicle does try to start.
Old 28 Dec 2009, 07:34 pm
It's very likely that you have a bad connection between your battery positive post and the main starter solenoid connection.
In that case if you use your jumper cables and put the plus cable directly onto the starter you will start immediately.
I've had to to this multiple times on multiple PT's.
A new quality battery cable is the simple fix.
Old 28 Dec 2009, 10:21 pm
jillibean03's Avatar
Send a message via AIM to jillibean03 Send a message via Yahoo to jillibean03
There is also the possibility of a bad cold start relay.
03 PT
95 Corvette
95 Firebird
Old 29 Dec 2009, 05:29 am
Good idea to look at the battery cables positive and negative ...the OEM positive battery cable and terminals especially are marginal at best...check for broken wire or bad terminal or corrosion, if in any doubt, replace them before condemning the starter motor. Again, be careful when troubleshooting around the starter motor...the vehicle could try to start.
Old 30 Dec 2009, 11:13 am
Many Thanks to everyone for replying.
The terminals have been replaced (corroded) but the problem was still there and now the garage has said it's the immobiliser!!!!
Garage has approached Chrysler for codes but will they give them to a garage and at what cost????
Also, will the key Fob need recoding or will the original code be given????
HELP!!!!!
Electrics/ switch problem - computer thinks a door is open Jargo Tech & Performance Forum 14 21 Oct 2014 04:24 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Ignition Switch??? Don162 Tech & Performance Forum 2 19 Aug 2009 11:03 am
msd ignition oeldisplay Tech & Performance Forum 4 19 Jan 2009 05:32 pm
Ignition Key uskeith Tech & Performance Forum 7 17 May 2008 05:45 am
