Hey folks I need you minds working on this on.. I have a 2001 Cruisser with an overheating problem, while driving on the highway the temp goes up about 1 bar on the gauge when I stop the temp goes back to normal or one bar below the normal line. Now I have changed to t-stat yesterday, but same problem I replaced the rad fan in the summer (July) but this only because it died. This overheating problem is perlexing because the system is not overflowing the catch bottle and there is no leaking or smell of fluid anywhere. I am thinking the temp sensing bulb? or the pump is toasted I reall don't know what to do. Any help would be great. Thanks
Al. |
The pump was changed about 20,000 KM's ago new timing belt and drive belts total milage is about 203000 kms. Drove to work today no problem getting there, check coolant level before leaving work this morning all ok but got on the hwy and the engine overheated and I lost all the coolant. The temp outside this morning was -16 so why would it even overheat? Also there was no heat in the cabin prior to the overheat condition.
Air in the lines?
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
The coolant is mixed right as per Chrysler, Car is parked outside always, engine block and battery heater installed and always on in cold weather. I just ran the engine again and the line to the rad is hot but you can squeze the hose flat. I am thinking air in the system, how do I bleed this? Just to check and see if anything comes out.
On the thermostat housing there is a bleed off valve. On one of the postings that Crewzin makes is a picture.
![]() Quote:
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring |
Okay so I bleed the system today but the bleeding screw is crossthreaded and I have to tap the hole to get it back in does anyone know how to remove that housing that the bleed screw goes into?
Thread Tools | |
Display Modes | |
overheating | earle | Tech & Performance Forum | 67 | 04 Oct 2010 06:49 pm |
03 Overheating | Cruisjim | General PT Cruiser Discussions | 16 | 24 Dec 2009 09:26 pm |
02 PT overheating?? grr... | fdrx7man | Tech & Performance Forum | 16 | 04 Jul 2009 12:15 pm |
PT OVERHEATING!!!PLEASE HELP | mtlhead79 | Tech & Performance Forum | 11 | 28 May 2009 09:21 pm |
overheating | missejd1963 | General PT Cruiser Discussions | 3 | 03 May 2009 08:39 pm |
